-   -   Valve Adustment Feeler Tool prototype (http://forums.pelicanparts.com/porsche-911-technical-forum/993902-valve-adustment-feeler-tool-prototype.html)
PatrickS 04-17-2018 10:40 AM
This isn't new, buts its been NLA for a long time. I decided to have a tool based on what island911 did years ago that is a little easier to hold and the feeler stock could be slid out from within instead of changing blades. Our host hasn't carried a version of it in years as far as I can tell.
So, based on the previous threads:
http://forums.pelicanparts.com/porsche-911-technical-forum/52062-better-valve-adjust-tool.html
http://forums.pelicanparts.com/porsche-911-technical-forum/67159-cool-valve-adjustment-tool-new-source.html
http://forums.pelicanparts.com/porsche-911-technical-forum/263129-island-911-valve-adj-tool.html
After briefly communicating with island911 and John Walker, this is a prototype I came up with:
http://forums.pelicanparts.com/uploa...1523983512.JPG
http://forums.pelicanparts.com/uploa...1523985019.JPG
This should make it easier to get to under the cat on my Carrera. The .004 Stainless stock slides in and out very smoothly. The tool is made from spring steel, sourcing strips of stainless or cutting 303/304 SS sheets was not cost-effective for a single trial. The crimp slider was just something bent on, I would have wrapped it all around if I wanted more effort into it. While this automatically puts the 90deg bend in the feeler stock and works very effectively, I think other iterations were straight and the user put the bend in it.
My machinist had absolutely no idea of what I was trying to put together, but I think it came out pretty well. What do you all think?
Len 911 04-17-2018 11:04 AM
will you be selling them?
PatrickS 04-17-2018 11:48 AM
I'm open. While some tweaking could happen, I'm happy with how this turned out. If others like it, great. I did not have my bender tool this for quantity, but if there's enough interest I'm open to having that done.
BlueWing 04-17-2018 12:07 PM
I might be interested in this depending on pricing of course. I have a 25' roll of Starrett .004 feeler stock I think #666. Should be beyond a lifetime supply.
Terry
nene 04-17-2018 12:54 PM
Count me in.
I have a feeling that the "lip" at the bottom of the tool may get in the way somehow, just a thought.
john walker's workshop 04-17-2018 01:25 PM
The bent lip will take up space that the blade needs. Some areas are pretty tight, and the blade should be able to get all the way under the elephant foot. The tip needs more grab area, as in flat, to keep the blade from pulling out. I have the 1st Island911 prototype with the bent lip and while it was a good idea, it just doesn't work as well as the straight model.
http://forums.pelicanparts.com/uploa...1523996716.JPG
PatrickS 04-17-2018 02:09 PM
^^^ Thank you John Walker.
I'd take the 90deg out. With the slider I can put a bit of tension on the pinch with the angle as I have the edge meeting the feeler stock - but I can test it more once the 90 is taken out. The slider can full wrap to avoid accidental loss.
John, I'd say we're pretty close?
http://forums.pelicanparts.com/uploa...1523999207.JPG
dyerkes 04-17-2018 02:42 PM
I would be in for one.
john walker's workshop 04-17-2018 06:27 PM
The lower lip should be a tad longer than the upper to support the 90 degree bend in the blade.
PatrickS 06-21-2018 09:17 AM
I finally got around to using a dremel to take off the lower extension of the prototype. Though I am not experienced with using a dremel, I believe this is good enough to show where I think the tool should be. What do you all think?
http://forums.pelicanparts.com/uploa...1529596797.jpg
http://forums.pelicanparts.com/uploa...1529596849.jpg
If people like it, my plan is to now go back to my tooling guy and see if the price on tooling for this can be within reason to make quantities for others who might be interested. Those of you who are interested, please email me to maximusmcgillicutty at gmail
