78 SC Oil Lines
Hi All
I have removed oil lines from rear wheel arch thermostat and apart from nearly stripping thermo threads (which will need thread savers) i have damaged one of the long oil lines to front.
see pictures below:
does anyone know if these can be repaired? I dont fancy blowing $6-700 on a new one!
any help appreciated.
Old 04-18-2018, 01:59 AM
Old 04-18-2018, 02:05 AM
Bill Douglas's Avatar
Maybe it could be brazed?
Old 04-18-2018, 02:08 AM
Alan L's Avatar
That looks like a collar brazed on the line. So the old one can be removed (ground off or sweated off). As long as you can obtain a similar fitting (maybe tricky) it can be brazed on.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 04-18-2018, 02:19 AM
JSZ JSZ is offline
I had a similar issue when working on my trombone cooler. You can sweat these off and reuse. I did have some new ones made out of brass that I installed also. Len Cummings supplied new 30 mm nuts for assembly.
Jeff
1982 911SC
1973 TR6
1979 124 Spider
1978 124 Spider
Old 04-18-2018, 06:20 AM
Thanks guys, any ideas where i could get some of these new collars? I'm based in UK but dont mind shipping from US if you know anywhere.
ta Jon
Old 04-18-2018, 06:42 AM
Also, what is thread size/type for the nuts on thermostat?
Old 04-18-2018, 06:51 AM
group911@aol.co's Avatar
See if one of the local shops has an old crushed line around and sweat an end off of it to use.
Thanks,
Bob
group911@aol.com
Old 04-18-2018, 07:41 AM
