Crotchety Old Bastard
RarlyL8's Avatar
Every car is different and so is every type and brand of tire. Some 9's fit no issue with 255's and some need the lips rolled. The 9's on the '87 red Carrera pictured below fit just fine, the green/gold '76 Carrera had to be rolled on the driver's side only as the sides are not perfectly symmetrical. Lots of variables but nothing that is a show stopper.
Old 11-04-2018, 11:04 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #121 (permalink)
mrbeverlyhills's Avatar
Bill Verburg, some nice 3.2s and SCs, will any EuromM fit on my 964?
BTW the Redline Fuchs in pieces were mine.
Old 11-04-2018, 12:02 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #122 (permalink)
kuba_kuba's Avatar
No need to roll fenders for me... 255s and 17x9 rears.
'88 911 Targa
Old 11-05-2018, 09:50 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #123 (permalink)
Bill Verburg's Avatar
Euromeister doesn't make wheels w/ the correct ET for 964.
Braid BZ are available, Fuchs look w/ custom ETs
8.5 ET48 w/ 235/40 x17
10 ET51 2/ 275/35 x17 would be a maxed fitment for a 964
Bill Verburg
Old 11-06-2018, 05:36 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #124 (permalink)
Jonny042's Avatar
I'm really liking the way the 225 tire fits on the 8" front wheel....... doesn't look pinched at all.
Just in time for winter storage, I had a chance to fit the widened to 8" fronts with the 225 tire. With the strut tops about 3/4 of the way in towards max camber, new offset balljoints (which move the bottom of the strut out by about 1/4") and a 12mm spacer, the wheels fit pretty much like the 7" wheels with the 215 tires.
I had a minor rubbing event when I hit a big dip and bottomed the front - I had to further roll a section of the left fender to prevent this. The right fender is either not original to the car or has been repaired and seems not to be a problem.....
keep in mind a few things - my spindles are raised 40mm, and I cut the Bilstein bumpstops to 2/3 original length, and I also have the shorter strut seal holders from Elephant. Plenty of travel with this setup so it tends to rub a little more severely than other setups.
Sorry for the crappy pic.
87 Coupe - The Driver
78 Backdate - The Project http://forums.pelicanparts.com/porsche-911-technical-forum/979976-project-heavy-metal-all-steel-classic-remastered.html
85 Coupe - The AX Beater
Old 11-06-2018, 05:48 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #125 (permalink)
All true to an extent
It's a very rare SC/Carrera that would have an issue w/ 9ET15 255/40 x17,(and usually because of some alignment or damage issue) Here's where the issues arise, use a taller tire even in the same width, say 9x16ET15 w/ 255/50 x16, The extra ~1" of height exponentially degrades the fitment ease.
255/40 x17 on 9.5 ET19, no fitment issues including ride height
Same wheels 275/40, these are a max fitment, oil lines relocated, suspension hardware trimmed, ride height compromised. The tire f/s is ~4.5" and b/s is ~6"
Bill Verburg
Old 11-06-2018, 05:50 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #126 (permalink)
Jonny042's Avatar
You could get a 7" front and 8" rear set widened to fit a 964 and get the offsets you need at the same time.
Obviously wouldn't be cheap but still economical overall. You'd have a unique set of wheels and it would look great.
Old 11-06-2018, 05:59 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #127 (permalink)
That may be fine(can cast wheels even be welded up?) if you are ok w/ welded up wheels, I'm not.
I'd avoid welded up wheels and spacers where ever possible
Bill Verburg
Old 11-06-2018, 07:07 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #128 (permalink)
Looks like Maxilite wheels are available and no material difference between them and Euromeisters other than grooves on the lips. May be the way to go for me.
Old 11-06-2018, 07:23 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #129 (permalink)
Bill, what abut these, shipped fro 100 bux to the us
https://www.design911.com/Porsche/964--911--1989-94/Fuchs-Wheels-17-/pt72_1679_-cma81-cmo107/
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #130 (permalink)
I know nothing about them other than they look to fit and are on the narrow side
The same outfit sell custom Fuchs lookalikes which appear to be the same Brais wheels sold here
Custom Fuchs look alikes
for 911 I'd want 8 ET28 & 9.5 ET19
for 964 the
8ET52 & 9.5 ET47
or
8.5 ET48 & 10 ET51
Bill Verburg
Old 11-06-2018, 09:41 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #131 (permalink)
for 964 the
8ET52 & 9.5 ET47
or
8.5 ET48 & 10 ET51
You can cram 10s on a NB 964??
Old 11-06-2018, 09:43 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #132 (permalink)
My SC on euromeisters. No problems.
Old 11-06-2018, 10:01 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #133 (permalink)
yes
exhibit A, A beautiful 964 built by Dan J, 8 & 10x18 245/35 & 275/35 tires
another nicely prepped 964 8.5 & 10 245/35 * 275/35 x17
Don't get me wrong, the more tire and wheel the more fitment issues will rise up
7 & 9 is an oe fit, a is 7.5 & 9 & 8 & 9.5 was used on Cups
Bill Verburg
Old 11-06-2018, 10:06 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #134 (permalink)
yes
Sorry, I know this has been thrashed already but I was under the impression the et had to be 55. so even if I got 7.5 or 8 inch fronts and 10 inch rears, the ET had to be 55. Is that not the case?
Old 11-06-2018, 11:42 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #135 (permalink)
ET is a fixed datum until you get to the max fitment regime
as ET goes down numerically the wheel moves outboard and vice versa, for smaller widths there is some room for play, the wider the wheel and taller the tire the less wiggle room
on a 964
oe fits are
front
6ET55 x16, 7ET52.3 x16, 7ET55x17, 7.5 ET55 x17, 8ET52 x17 , 8ET52 x18
rear
8ET52 x16, 9ET52.3 x16 8ET52 x17, 9ET55 x17, 9.5ET47 x17, 9.5ET47 x18
Bill Verburg
Old 11-06-2018, 11:55 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #136 (permalink)
Jonny042's Avatar
Found this pic and thought others might find it interesting - one the left, my latest rear setup which is a 255/40-17 RE71R on a 9" wheel, and on the right is a 245/40-17 Dunlop ZII on an 8" wheel. I never really thought the 245 on the 8" looked pinched until I looked at it side by side with the 255 on the 9".
Old 11-09-2018, 07:32 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #137 (permalink)
Cars and Cappuccino
tdw28210's Avatar
Yes, the barrel grooves and whatever the Chinese version of TUV approval is.
http://www.carsandcappuccino.com
1987 Cherryrot G50 Coupe
1985 Prussian Blau M491 Targa - 1 of 65 in the US
1977 Mexico Blue flared, 3.2, back date, sunroof-delete Coupe - in process.
1972 Black T coupe to Longhood Turbo R5 tribute car (someday)
Old 11-09-2018, 07:41 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #138 (permalink)
Jonny042's Avatar
Interesting data point for fitment if anyone is interested, RUF wheels for the Carrera:
(Ruf used 215 front, 235 rear, tires on these).
Old 11-10-2018, 05:50 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #139 (permalink)
Jonny042's Avatar
Try that pic again:
Old 11-10-2018, 05:53 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #140 (permalink)
