Installing 6-point harness (mounting points)
Hi
I was wondering if someone could please be so kind and take some simple measurements for me; 1. In a SC or 3,2 911, measuring from the firewall below the backseat, how far forward are the "ears" used for the lap belt welded on the tunnel? 2. Again measuring from the firewall, how far forward is the out lap belt mount? 3. The anti-sub strap (ball crusher between your legs), again measuring from the firewall, how far forward have you welded the plates/bolts to the floor? I know this could vary a little depending on how tall you are, but I'm looking for general guidance. Cheers! Johan |
http://forums.pelicanparts.com/uploa...1524350491.jpg |
Thanks Bill!
Johan |
I strongly suggest following the instructions provided by the manufacturers of the belts. They can be very specific.
If you have belts with no instructions, it might be a good idea to contact the manufacturer. |
I have Schroth's Profi harness: https://www.schrothracing.com/docs/Competition_Instructions.pdf
The measurements above from Bill will be a good starting/reference point Johan |
Main issue can be the shoulders, 1) you need seats w/ the shoulder holes in the right spot wrt the top of the Hans 2) the bar the shoulder strap wraps to needs to be the correct height wrt the top of the Hans Also it's nice, if allowed, to use a sub strap bar instead of drilling holes in the floor |
Seats will be Recaro Pole Positions
Johan |
You need a straight fetch w/o any seat interference from the Hans to the bar. Your situation will depend on your seated shoulder height and the height of the bar. |
| All times are GMT -8. The time now is 07:09 AM. |
