Sven
Alarm lock cylinder able to be disassembled?
Hi brains trust!
My next riddle: have bought the correct HUF key blanks for my alarm system cylinder/lock... but how do I now access the barrel for a locksmith to cut the keys to work in the existing lock? It seems to be pressed/glued together. Cannot see any way to access the barrel without destroying the cylinder... Anyone any ideas or has done this before? Or do the locksmiths have a magic way to cut keys without having to pull out the barrel? Appreciate your help.
Sven 1985 Porsche Carrera LHD black on black 1970 Citroen DSuper RHD Bleu Platine with Blanc Cygne roof 1968 Porsche 911 LHD red on black (sold - shouldn’t have...) |
Hi: If it was me, I would bring it all to my locksmith and ask him how he will make the key.
Platinum Member
Nevermind, my bad, see post below. Thanks/
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams Last edited by dad911; 01-04-2018 at 10:05 AM.. |
I think the alarm switch has 2 distinct resistance values. One for armed and one for disarmed. If you simply unplug it I believe it defaults to armed. I'll check the manual and update with details here shortly.
A great locksmith can dust the key and cut to the dust imprint on the wafers.
There use to be a guy cutting keys at Hershey, Ski Roundtop, and Mechanicsburg, P/A and he would cut to blanks and make keys from ignition cores. If you disconnect the switch, car won’t start Bruce |
Alarm switch on should give 2-3 K ohms
Alarm switch off should give 4-5.5 K ohms So if you remove the switch, you will need to replace it with a resister of the correct value. |
Sven
The switch will definitely be reinstalled, so no need for dummy resistors or else. Will take the whole shebang to a locksmith and see what they can do.
Just thought someone might have pulled the barrel out somehow and rekeyed it themselves like people did with the door locks.
I recall seeing an ad for an Aussi or NZ locksmith who can cut a key from a picture or dust the tumblers. A little google searching should find it.
Bruce |
'84 Carrera Targa (3.0 with SSIs, Webers, DC-19 Cams, MSD) - Sold |
More cars than sense
