G50911's Avatar
another 3.6 fuel line question...
recently replaced all my fuel lines and i noticed when i first tried to start the car that there was fuel coming out of the fuel filter (in the engine bay). i tightened the banjo bolt and if i nudge the hose i can hear pressure leaking from the hose fitting. i have this type of fuel hose clamp (see first pic).
are there special requirements for clamps rated for fuel injection due to working pressure? thinking i need to replace clamps to this style, thoughts?
1967 911 (Azzuro Thetys) - #308439
1971 911 (PTS Black) - Built 3.6 Sleeper
1989 911 (Grand Prix White) - Cabriolet Bone Stock
Old 09-02-2018, 07:51 PM
3rd_gear_Ted's Avatar
60 PSI is what your dealing with.
Crimped hose is usually used.
1980 911 - Metzger 3.6L
2016 Cayman S
Old 09-03-2018, 09:49 AM
Those top clamps are pretty useless.
206 637 4071
Old 09-03-2018, 01:50 PM
G50911's Avatar
swapped out the 4 in the engine bay today (supply to filter, filter to regulator line, regulator line and return. i noticed the shop also used the "bad ones" at the tank. i guess i need to trace them throughout the system and replace them. (#*$%&!)
Old 09-03-2018, 03:03 PM
