-   -   Glove box lock re-key. (http://forums.pelicanparts.com/porsche-911-technical-forum/994365-glove-box-lock-re-key.html)
86 911 Targa 04-22-2018 12:40 PM
http://forums.pelicanparts.com/uploa...1524425772.jpg
http://forums.pelicanparts.com/uploa...1524425933.jpg
Can any locksmith re-key a glove box lock
using the ignition key?
Thanks in advance,
Gerry
DRACO A5OG 04-22-2018 02:30 PM
No need, you can remove the cylinder by pulling out the pin with a needle nose plyers. The pin is located in the groove in the middle, just take note of the spring mechanism.
My spring broke and I used an VW bus spring from their glove boxes, same manufacturer :-) $14
mepstein 04-22-2018 03:04 PM
If you don’t want to diy, send to “tweet” / Dan on this site. He’s done a lot of work for me, first ding broken ignition locks and making missing keys from just the lock core. Very reasonable price, fast turnover. Highly recommend.
smadsen 04-22-2018 09:37 PM
Any competent locksmith can re-key. A Porsche shop will have an assortment of the little tumbler bits. No matter who does it, it's a 5 minute job & should be inexpensive if you walk in with the pieces in hand.
86 911 Targa 04-24-2018 12:57 PM
RSD Glove box re-key.
So far the estimates to re-key both locks
is between $130-$210.
Gerry
LIRS6 04-24-2018 12:59 PM
Gerry
Tell them it's for a Yugo ... $25
86 911 Targa 05-11-2018 03:38 PM
Torrance Lock & Key did both of the locks for
my rear seat delete for $25 each.
Gerry
