Elombard's Avatar
Broken Heater flapper box stud, options to repair?
I should not have tried to take those nuts off.
The studs are welded into the body with no access from the underside. I think they were welded at the factory before the rockers were installed.
Any body have a solution short of removing the rocker metal?
Thinking about grinding it smooth and using a sheet metal screw to attach. Not sure I can drill it, might have to wait until the engine is out again.
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 04-21-2018, 06:40 AM
If just one broke, the other two will do the job. I'd leave it as is.
206 637 4071
Old 04-21-2018, 09:21 AM
Elombard's Avatar
Thanks John,
Yeah I am leaning that way. Does not seem like there is any way to replace those studs with out serious surgery.
Also seems like the flapper box is very secure with 2 attachment points
Old 04-21-2018, 09:33 AM
I drilled and tapped mine, worked a treat
Old 04-21-2018, 11:07 AM
Elombard's Avatar
Ahh, so there is enough "meat" there to tap and just use a bolt?
Old 04-21-2018, 11:39 AM
I'm with John. It's been 5 yrs since I replaced the flappers, and I broke one stud. The other two do a fine job of holding it in place.
Dave
1969 911T Coupe
1972 911E Targa
Old 04-21-2018, 11:56 AM
wrxnofx's Avatar
I was very nervous about this when I did the R&R to my flappers. The nuts that came off had the nylon locks, which I think helped. Slathered a ton of anti seize upon reassembly.
1987 911 Carrera coupe - Guards Red
2010 997.2 C4S 6-Speed
2005 Mini Cooper Convertible (R52) - Wife's car
1977 VW Bay Window Camper Bus
Old 04-21-2018, 07:06 PM
Counterclockwise?
I broke a few of them and had to weld on new studs.
Old 04-22-2018, 11:32 AM
Two will hold just for, but I also drilled and tapped a few
Old 04-22-2018, 06:10 PM
