Looking for Non Collapsable Spare Tire Options
I’ll be driving from Minneapolis to Rennsport Reunion this Fall, and am looking for a spare tire option that does NOT use the collapsable spare for a more legit option just in case a flat happens. Car is an ‘87 Carrera.
I have seen guys use a narrower Fuchs with an actual tire, but I also want the thing to fit into the fuel tank indentation. Lay it on me, community - what are my options?
1987 911 Carrera coupe - Guards Red 2010 997.2 C4S 6-Speed 2005 Mini Cooper Convertible (R52) - Wife's car 1977 VW Bay Window Camper Bus |
Formerly known as Syzygy
That'll be a great trip to be sure.
As for the tire, it'd have to be the same size as the collapsed factory spare to fit into the spare tank indent. I don't think you have any way around that. I think a full size 25" diameter tire mounted to a 6" Fuchs would still fit in the trunk, so that's an option, but there won't be a lot of additional room for luggage and whatnot. I think also that a tire plug kit, some fix a flat and a compressor would suffice. That and your collapsible spare should get you to a place that could fix your flat or sell you a new tire if necessary and mount it to complete your journey.
Kevin 1987 ROW coupe, Marine blue, with a couple extra goodies. The cars we love the best are the ones with human traits, warts and all. |
(man/dude)
Kev is right - the additional crash protection structure in the front tub takes up the space you need to fit a full size tire. On the upside, there is room for the jack.
Heavy Metal! Part Deux - The Carbon Copy Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD) 85 Coupe - The Rot Rod! AX beater Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911 |
Okay, stupid question then - if I inflate my spare at home to verify it works, will it shrink back down when I let the air out of it?
One other thing you might check is if it will actually fit on your car; depending on how your wheels and suspension may have been upgraded over the years, the spare may be too tall to fit.
Rutager West 1977 911S Targa Chocolate Brown |
I think the inflated diameter of the collapsible spare isn't quite the same as the regular tires, so if you get a flat on the rear, put your spare up front and move your front to the rear. I'm not a hundred percent on this so others should chime in if I'm wrong.
What is the life of this type spare? If it sits in the car for 30+ years is there any chance you can inflate and drive eon it without it being dry rotted at the seam?
Two years ago I used mine. I inspected it carefully for cracking and visible deterioration of the rubber. It looked good, but I was nervous as hell about using it. I kept my speed down and drove carefully and kept the radio off so I could hear any weird little noises. I got home let the air out and put it back in the trunk. It worked flawlessly for 400 kms. I had two backup plans if the tire failed before I got home, actually three depending on where I might have a failure. I didn't need any of them.
If used in a situation where the options look less appealing, these spares are good. But I stress that you should provide yourself with options before using a thirty year old tire. Mine is always in the trunk out of light. It's cool here (generally) so no temperature damage. I think one of the biggest areas that might fail would be where the tire is kind of folded over on itself when collapsed. In the end, I suppose, use your head and some common sense. And if you don't trust it to use in a pinch, might as well take it out of the trunk and ditch 30 lbs of weight.
Kevin 1987 ROW coupe, Marine blue, with a couple extra goodies. The cars we love the best are the ones with human traits, warts and all. Last edited by Canada Kev; 04-22-2018 at 11:21 AM.. |
'73 911 T Targa
I assume you're saying to keep the diameters equal so you don't mess up the transaxle? I ask because I recently read that you should end up with the spare on the rear so that if the spare fails, you can still steer. |
'73 911 T Targa
I'm also trying to find a conventional tire that fits. The closest I got is a 155/60R15 which gives you an O.D. of 22.4 or a 145/65R15 which gives you an O.D. of 22.3
I have a space saver spare that I bought several years ago at a swap meet. I recently inflated it and it looked fine and in theory, since it's not in the sun, it should last a good long time, but at this point, I'd probably never be able to really trust it. Oh and by the way, it does re-collapse when you deflate it. |
Vintage Owner
I’ve never measured, but I wonder what is the largest diameter tire that would fit in the spare tire well? Even a mini-spare might make you feel better than a 30+ year old collapsible spare at this point. Otherwise, just get a flatbed tow!
84 Targa (sold) 70 914-6 (sold) 73 914-6 2.7 conversion (sold) 75 GMC Motorhome (sold) 2016 Cayenne |
On the other hand, and this is a bit of an apples to oranges comparison, but on my older AWD daily, the front wheels must be the same diameter (or within a couple percentage points) as the rears so as to not muck up the centre diff. So if I want staggered wheel sizes on my XI, I have to be sure they're very close to the same diameter.
Kevin 1987 ROW coupe, Marine blue, with a couple extra goodies. The cars we love the best are the ones with human traits, warts and all. Last edited by Canada Kev; 04-22-2018 at 02:41 PM.. |
You raise a really good point. What is the stud diameter on these hubs for a spare. Do I have to worry about offset or other measurements?
My collapsible tire is still usable after its 40 years trunk life. I'm just curious if they are still available and its cost.
Sent from my LG-H900 using Tapatalk
![]() 911 C2 Turbo Look ![]() Harley Fat Boy ![]() Jeep TJ Sporttrac Adrenalin![]() 911 SC(sold) Sporttrac(sold)
Matt- We should get a full size spare for one of the longhoods. If an impact bumper car gets a flat, they can borrow it to get to the next town for a patch/replacement. I'll run without a spare and use the space to bring a bigger jack. We should also discuss who's bringing what spares and tools so there's no redundancy. I think there are a few threads on this subject.
Vintage Owner
Here’s a long time PCA member’s solution! 😄
'73 911 T Targa
If you find a wheel that fits that's smaller than 15" please let me know |
Vintage Owner
A 14” Fuchs is made, though I don’t know if it will fit over larger calipers.
Cars and Cappuccino
A guy is selling new vintage style roof racks on the parts forum. Should hold several mounted tires and some other stuff too. 😉
