1973 T Wiper switch wiring
On my 1973 T wiper switch wiring I have a brown with white stripe wire that i do not know where it goes. It looks to come straight from the six pin connector under the dash.
Thanks for the help
Old 04-24-2018, 05:35 AM
Administrator
Dmitry at Pelican Parts's Avatar
Hello - if our members do not get back to you. Please feel free to give us a call at 888-280-7799 and one of our Porsche part specialists will be able to help out.
Old 04-24-2018, 12:53 PM
HarryD's Avatar
Thanks for the help
Looking at my wiring diagram, the brown/white wire (switched ground) looks to be the switched ground that is connected to the horn relay. The striped wire connects to your horn button (connection point 82a), goes to the 6 pin connector and then to pin 85 of your horn relay.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 04-24-2018, 10:08 PM
HarryD's Avatar
You can find the wiring diagrams for your car here: https://www.pelicanparts.com/911/911_Parts/911_electrical_diagrams.htm
Harry
2020 MB E350 4Matic
Old 04-24-2018, 10:30 PM
From what I see, the turn signal has a brown and white wire that connects to the horn button ring under the steering wheel. The brown wire connects the body ground to the screw that holds the horn ring under the steering wheel. Now I have the one brown and white wire from the wiper harness with no place to land. It has a female connector on it. The car had an after market steering wheel on before. I now have the correct steering wheel. Does the switched ground go to some place on the horn button itself?
Old 04-25-2018, 04:59 AM
I believe i have found the issue. One of the brown and white wires is not used. This may have been there for optional steering wheels. Can anyone confirm this.
Old 04-25-2018, 05:30 AM
