AV8TOR
Please Identify this Bosch Fuel pump
I have a fuel pump that I am trying to identify. I don't know if it is a pump that is used for either Webers or MFI.
Bosch # 0580 97000
I am hoping that it is a low pressure carb pump.
Any guesses????
AV8TOR
pokemon
Old 04-21-2018, 06:52 AM
Functionista
manbridge 74's Avatar
Are you sure the number doesn’t end in 01? I believe the pump used for Weber’s/Zenith is of the 0580 96000 series so this might be a MFI pump. Hook it up to a test rig to measure pressure?
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 04-21-2018, 07:03 AM
Functionista
Also does it have three ports the same size? MFI always had a 10mm suction and 8mm on the delivery and return ports.
Jeff
74 911, #3
Old 04-21-2018, 07:08 AM
AV8TOR
Thanks for taking a stab at it Manbridge 74........
All three ports are 7mm OD, and none of the ports is labeled (as "P" "R" or ?)
Where in CO do you live???
Old 04-21-2018, 03:30 PM
clarkd's Avatar
Here's another data point. I have a Bosch "carb" pump. Model number is 0 580 960009.
Puts out around 4 psi. Also has Germany and 952 stamped on it.
Old 04-21-2018, 06:24 PM
AV8TOR
Any guesses???
Old 04-22-2018, 04:58 AM
AV8TOR
I am told by a reliable source that this is indeed an MFI pump.....
AV8TOR
Old 04-25-2018, 07:37 AM
