You might want to contact this guy.
http://forums.pelicanparts.com/porsche-911-technical-forum/1056963-converting-911sc-doors-back-stock-rs-help.html |
I will post them shortly - I’m thinking they’ll cost about $140-150. I spent a lot of money on the casting mold and they aren’t that cheap to produce. Pricey but they’ll be awesome.
just ordered the black AK-handles. from a distance they look beatifully made, cnc cut and seem solid. And they fit the same bolt pattern I already have (15cm). The ones I have (posted page 1) are ok, though I had to redo the coating and I fear they may bend one day. |
originally the porsche used the same ones used in a fiat 500
and they are cheap. 2,05 dollar but shipping from italy. https://www.fdricambi.com/en/fiat-500/door-parts/do1002-door-handle-plastic-fiat-500-126-600 |
well, yes, back in the days they took what was ready to grab at armlength.
doesn't mean you can't do a bit better today :-) |
daugaard is spot on...
Here's what I did. I didn't like the ones that came in the kit, so I just cut up an old belt. I might get a nicer piece of leather and re-do eventually, but they work really well and hold up well being attached to the door directly.
https://i.imgur.com/H234cGj.jpg |
I made mine out of aluminum flat bar wrapped with leather hand stitched in the inside. Kept the aluminum exposed at the end to match the Momo steering wheel.
http://forums.pelicanparts.com/uploa...1586625139.jpg http://forums.pelicanparts.com/uploa...1586625261.jpg |
| All times are GMT -8. The time now is 11:21 PM. |
