Rennline floor boards
So, is it really necessary to cut up my new carpet to install Rennline perforated floor boards?
Tom Feeney
1970 911 T
1973 911 T
Looking for engine 6103643
Old 04-25-2018, 06:07 PM
Install over top of carpet just like stock floor boards, only mats would cover if you chose to use mats
82 SC Twin Plug 3.2 SS ,46 PMO
Old 04-25-2018, 06:18 PM
Zaz Zaz is offline
Mine would not go in over the carpet-impossible to get the short base mounting bolt through the board hole over (vs under) the carpet and insulation. Not an issue for me as my carpet is old so I just cut away, but I will be looking to replace it next winter so curious how others have addressed this.
74 911 Coupe
74 Triumph TR6
97 Jaguar XJ6
Old 04-26-2018, 11:42 AM
Yep, if it was old carpet I wouldn't even worry but it is brand new.
Tom Feeney
1970 911 T
1973 911 T
Old 04-26-2018, 12:38 PM
Bucketlist's Avatar
When I installed mine a few years ago they wouldn't fit. After putting it aside for a while I decided to compare the new floorboards to the old and found the wooden floorboards had been trimmed on the corners to fit my thick aftermarket carpet. I trimmed the new floorboards to match the old and everything worked.
Good luck!
1981 SC Steel Widebody Outlaw in Pacific Blue and Artic White, 930/51 to 3.2l, K27 7006 Turbo, P&P Twin Plug heads, Twinfire Ignition, BLwur, Ruf Intercooler, Powerhaus headers, Zork, CIS Euro FD, 009 injectors, DOD, DP Lid, 044 pump, 930 4 sp LSD, Mocal 44 w/fan, LM2, Brembo, Retroair, Euromeisters.
Old 04-27-2018, 05:19 AM
