Exhaust header/heat delete
I have replaced my heat exchangers with custom headers.
As per picture (arrow), this tube now blows air to the ground. Should I let it be or should I have it blocked off ? I have no need for heat.
Old 04-24-2018, 12:53 AM
safe's Avatar
Its better than to not blocking it off. Keeps heat and dust from entering the engine bay from that direction. Allowing the cooling fan only air from the the engine lid.
The most important is to block of the hole in the shroud that now feeds the fan.
Magnus
Old 04-24-2018, 01:29 AM
AndreasK's Avatar
Remove all the ducts and fan. Lots of unnecessary weight if your not in need of heating. Block of the hole in the shroud, yes.
1977 911s
Old 04-24-2018, 01:48 AM
Thanks guys
Old 04-29-2018, 10:49 AM
