Vent window seal between frame and body?
See picture below.
Is #16 the seal between the door body and vent window frame? I just took my window frame out and there is some dry goo almost like gasket sealer on the bottom of the vent window frame. I am wondering if the previous owner used it in lieu of a proper seal. BTW I have a 71T Thanks. http://forums.pelicanparts.com/uploa...1524974086.JPG |
Butyl Tape / Caulk
Can't tell what item #16 is from the diagram, but the "dry goo" you are referring to is an OEM sealant.
When I replaced my window vent frame I replaced the original dried black caulk with butyl rubber tape / window sealant. Most local auto parts places carry it. Gordo |
There is a seal with “piping” for 74-89 cars for this application. I don’t know if it would work on a 73 or earlier car. I would go to the Early 911S Registry and search.
Best Chris |
| All times are GMT -8. The time now is 10:09 AM. |
