-   -   Dumb injector o ring question...sorry (http://forums.pelicanparts.com/porsche-911-technical-forum/995107-dumb-injector-o-ring-question-sorry.html)
Nick Triesch 04-29-2018 02:51 PM
I am in the process of replacing the 6 intake gaskets on the passenger side of the motor. While removing stuff I pulled off the fuel rail and pulled up and pulled all three injectors out. Injectors are fine but I want to replace the bottom o rings before going back in. . My question is, why are there 3 regular o rings in the kits that I bought from Pelican? I understand the one on the bottom, and the one for the top if I was going to replace it, But what about the third o ring. Also, do I really need the new yellow hat and the skinny gray plastic ring? i cannot find much info on replacing the injector o rings. Please forgive me, I'm learning as I go along. BTW, in the 7 years that I have owned my car the hardest thing I have ever done on the car is trying to remove the fused paper intake gaskets on the head!! Gaskets from Hell. But, slowly getting them off. I am getting all vacuum leaks fixed before I move on to other problems. Thanks, Nick
Targa Me 04-29-2018 03:04 PM
If you remove an o-ring, replace that o-ring.
If you remove the yellow hat, replace the yellow hat.
If your injectors don't use the skinny gray plastic ring, don't worry about it.
Nick Triesch 04-29-2018 03:25 PM
Thanks!!
