Please I need help about Blaupunkt Radio and Amp wiring harness.
Hello everyone, sorry for my English. I have a 1984 Porsche 930 Coupe. Currently my car has an Alpine radio installed (the fashion of the 90's, cassette change by CD) and I'm planning to reinstall the original Radio SQR 22 + Amp BQB-80 Blaupunkt back. Please, if someone has pictures of the original wiring harness connection (both: radio and amp), I will appreciate if you share the photos with me, thank you. Something I would like to know is if in the constant 12V radio wire I should install a fuse in line, or if this is not necessary; concerning the Amp, I think that is necessary to place the fuse in line, because I suppose that the constant 12V wire must be connected directly to the battery, but I'm not sure. I'll appreciate any help (photos or comments), that you can give me. Thank you very much!
Leandro
Old 04-25-2018, 08:39 AM
Administrator
Dmitry at Pelican Parts's Avatar
Hello Leandro - take a look at the link below - I hope this helps you out a bit. Please let us know if you have any questions or if we can assist with any part needs in the future.
https://www.radiomuseum.org/r/blaupunkt_atlanta_sqr_22_7642885070.html
Old 04-25-2018, 12:38 PM
Hey Dmitry, thank you very much for the link, I'll check it this weekend. Of course, I'm a Pelican Parts client; my favorite place to buy any part needs, thanks. If you have any wiring harness for the Amp Blaupunkt BQB-80, pls just let me know!
Regards...
Old 04-26-2018, 05:11 AM
Eng-o-neer
Tremelune's Avatar
The radio head-unit wire is fused at the fusebox from the factory. If you add an amplifier, you will want to connect it directly to the battery with a fuse close to the battery (sized to match the gauge of the wire).
Old 04-26-2018, 02:50 PM
Hi Tremelune, I really appreciate your comment; thank you so much for your help. In this case, I just need to connect an inline fuse to the Amp 12 V constant wire directly to the battery, and it is not necessary for the radio head-unit 12 V constant and 12 V ignition switch wires (according your comment, wires are fused at the fuse box from the factory). About your mention concerning add an amplifier, my 930 has the Blaupunkt BQB-80 in place (I think from factory), but missing the wiring harness. Can you please let me know if I could connect the Amp 12 V constant red wire to one of the no wired hot connector in the upper section of the fuse box (of course with the inline fuse) and the ground brown wire to the ground bolt near to the fuse box?
Sorry for my English, I hope you understand what I'm trying to say.
Best,
Leandro
Old 04-27-2018, 09:23 AM
Please Tremelune, see the following photo for reference about my question. In circle green (Amp ground), and in circle yellow (Amp 12 V constant). Can I connect the wires in those places?
Thanks in advance for your time and help...
Old 04-27-2018, 09:55 AM
Eng-o-neer
Tremelune's Avatar
I don't think any factory wires will have a thick enough gauge for the amplifier. What is the amplifier? Most that I've seen run with at least 10AWG wire directly to the battery with a new fuse.
Old 04-29-2018, 04:07 PM
Hi Tremelune, thanks for the info. I'll check 3 red wires that my car has from the battery to some places that I do not know where yet. I appreciate your emails, thanks again for your time and help!
Best,
Leandro
Old 04-30-2018, 02:37 PM
