engine case interchangeability
I have a 2.7 engine with a 7R case that I need to replace with aluminum one white at the rebuilding process, is it possible to retain all the internal parts but use a 3.0 or 3.2 case instead? do I need to replace the pistons/cylinders with case as well?
is the cylinder fitment the only issue here? |
A replacement aluminum case for the 2.4/2.7 cases would be more stable, but a properly prepared magnesium case can be a good base for a great engine. Folks forget that the 3.0 liter engines now are old enough that they also need a fair amount of work, and are equally expensive to update for additional performance.
| All times are GMT -8. The time now is 02:47 AM. |
