-   -   ColourTune spark plug to troubleshoot ignition (http://forums.pelicanparts.com/porsche-911-technical-forum/995322-colourtune-spark-plug-troubleshoot-ignition.html)
911T70 05-01-2018 05:33 PM
My '70 911T is running rough this spring and I suspect the ignition. While tuning the carbs using a ColourTune spark plug, I was surprised to see flashes of light (running too rich in this case) at a variable frequency! I calculated that there should be a spark at 1.4 Hz at 1000 RPM but, as you can see on the video linked below, there seems to be missing sparks. I looked for ColourTune videos on YouTube and saw some that show the same behaviour. Shouldn't there be a flash at every second revolution?
https://youtu.be/kimvO4NXewg
Thanks!
rbogh901 05-01-2018 07:12 PM
Good question. I always thought maybe it would just be too hard to see all of the flashes and so didn't expect to be able to count them and correlate with RPMs. In any case, you are correct, needs more blue, lean it out a bit.
911T70 05-01-2018 07:24 PM
At idle, 1000 RPM, each cylinder should fire at close to 1.5 Hz, which is easy to see. Have you used ColorTunes and observed the same behaviour, where sparks seem to be missing?
And yes, that cylinder was leaned out!
Gordo2 05-01-2018 08:52 PM
My Observations
I've used the ColorTune to adjust my PMO carbs.
My spark is intermittent (just like your video) when I lean out the idle mixture screw a bit too much.
When adjusting the mixture screws with the ColorTure - I normally adjust until its starting to lean (intermittent white), slowly adjust / open the screw until it starts to go rich (initial / obvious yellowing) and then set the screw at the mid-point in between (blue).
I've found with this process the engine ends up a little rich overall, but runs nice and smooth - much smoother than I've ever been able to get it tuning by ear using the lean drop method.
Good luck.
T77911S 05-02-2018 03:51 AM
you are making this waaaay too complicated.
follow the advice above.
I the mixture is off enough for a cylinder the may or may not fire.
great tool. I bought one for my CIS 930.
911T70 05-02-2018 04:02 AM
Thanks for the advice, but I'm troubleshooting the ignition and trying to determine if sparks are occurring like they should. The car runs rough, feeling like it's not firing consistently. Maybe the ColorTune isn't the right tool for this.
I'd still like to understand why we don't see a steady pulse of light though, especially when running rich (intermittent when too lean according to Gordo2)!?
Gordo2 05-02-2018 07:47 PM
Ignition vs Fuel
Based on your video - it looks like you have that carb's mixture setting lean, causing that cylinder to fire intermittently.
When i'm using my ColorTune - it's pretty obvious when the carb mixture setting is too rich. The cylinder tends to fire in a regular, timed / consistent pattern when rich - but the flame appears as a lazy yellow as opposed to a sharp, consistent on / off blue or white as I lean the carb / cylinder out; ultimately progressing to an intermittent flame when adjusted too lean (just like your video).
Next time I break out my ColorTune I will try to get a video. Good on you for videoing the the shot you posted - it can be a challenge just getting a mirror positioned in the right spot to see what's going on, let alone doing so while trying to get a camera at the right angle / position to capture the image... You don't by chance have 3 hands?
If your ignition is in relatively good condition (dizzy cap and rotor are in good shape) - I can't imagine what could cause it spark intermittently as per what you are seeing. As such, I tend to think the issue is associated with the fuel delivery / carb.
Gordo
1QuickS 05-02-2018 10:15 PM
Too rich & too lean will cause a cylinder to not fire. If lean then I have found that the spark will jump someplace else than at the tip of the spark plug, such as between end of the cable and the inside of the Colortune if insulation is not good (old plug wires or dirty porcelain).
When using Colortune, be sure you can definitely adjust mixture to rich (orange) and then cause it to go blue. I screw mixture screw 1/4 turn per adjustment & then wait for a slow five count to allow settling.
If you have air leaks around the throttle shaft then you will have enough erratic air coming in through the bearing/shaft interface that the mixture will go lean & then back again. These air leaks typically begin to appear for Webers with mileage around 90k miles.
911T70 05-03-2018 04:00 AM
Thanks a lot for that information! I'll try tuning the carbs again soon following your advice and hopefully I'll get them in a state where the color looks good AND firing is consistent. My distributor/rotor/wires/plugs are all new but my CDI is the original Bosch, which is why I'm worried about the ignition. I can't believe that circuitry still works!
Getting the mirror and the camera at the right angle was not easy, but at least I didn't get shocked like I did a couple of times last year. I'm always terrified when I'm positioning the mirror around the plug cable; I should look for a plastic one!
My Zeniths were re-built recently so I don't think I have air-leaks, but this possibility is good to know and I'll keep it in mind.
Thanks again!
fizeus 05-03-2018 07:30 AM
If you suspect an ignition problem you HAVE to use a timing light.
Hook it near the spark plug and point it to engine pulley... Timing marks will guide you to the diagnosis.
Do not forget that spark are provabilistic events so do not worry to much if you see some erratic behavior......
Also you can use timing light in conjunction with the colortune... If you see missing sparks on the colortune and not to the timing light try changing cables.
Here is my cent
1QuickS 05-03-2018 08:42 AM
I use a mechanic's mirror to view the spark; the kind with a mirror on a stick with a swivel to connect them. I tossed the plastic tube thingy. The mirror I like is 1" wide by 2" long. I bought mine through McMaster-Carr, the world's BEST source for quality tools & sundries! Part number 1017T17.
Zeniths tend to maintain throttle shaft/bearing fitment quality longer than the Webers do. However, "rebuilding" does not address the issue I describe. "Rebuilding" typically is cleaning & gasket replacement only. Throttle shaft/bearing fitment is a much more invasive procedure.
911T70 05-03-2018 04:24 PM
I should definitely get a larger mirror, preferably non-conductive! I tried using an inspection camera (borescope) but the high voltage messes up its electronics and it shuts off. Too bad, because it would make visualizing the plug so much easier.
304065 05-03-2018 05:06 PM
I wrote this a while back. . . enjoy
Adventures with the Gunson Colortune on an SWB 911.
T77911S 05-03-2018 06:38 PM
I use a round mirror about 1.5 inches in dia. i don't use the mirror that came with it.
i of course have the long adapter on the color tune(CT) but i put heat shrink over it to keep it together. i need to go back and glue it then heat shrink it all.
i lost the washer that goes on it so i don't use one and cant tell any difference.
i loosen it the plastic tool then use the part that the plug wire goes on to remove it.
make sure you get a good snap when you connect the plug wire. i only had spark jumping issues when i did not have a good connection.
911T70 05-03-2018 07:20 PM
Thank you! I hadn't thought of using my iPhone to see the plug. I'm surprised the electrical field from the high voltage doesn't affect it. I'd be worried that it might damage it or wipe its memory.
You mentioned Bosch Distributor Lube in your write-up. I've been looking for it - do you know where it can be purchased? Seems to be NLA everywhere I've looked?
911T70 05-03-2018 07:31 PM
I use the Klein spark plug tool through which the long extension can extend. I added a layer of electrical tape to the nut adapter so that it stays jammed in the Klein tool when I remove it after threading in the ColorTune plug. I had a terrible time with the washer that came with it, loosing it a few times inside the cavity, so I use a washer from an old plug, which stays captive so it never falls off. I hated using the ColorTune at first but now that I've used it a few times, I've improved my technique and it's not so bad. It's certainly worth the effort and it's paid for itself just with the improved fuel economy!
1QuickS 05-03-2018 09:05 PM
Some of my hard-earned Colortune tricks:
*I never used the washer; not needed for low RPM operation like idling.
*A magnetic wand is handy to retrieve the Colortune if it falls out of the socket.
*I cut an internal chamfer in the end of the extension lead to maximize the chance to mate it with the threaded end on the Colortune.
*Like 911T70 stated: The Klein spark plug tool is handy if you have one.
T77911S 05-03-2018 10:12 PM
no washer. lost it second time I used it. I think it is in #6. no need to tighten it very tight either. I just use the extension for the CT to tighten and then remove once I break it free with the plastic tool.
one day I will glue the extension permanently to the CT.
rbogh901 05-04-2018 08:54 PM
Good luck.
Yes. There is no way I could come close to the accuracy listening the way I tried to in the past. The visual cues are so much more precise and get things within a quarter turn reliably where waiting for an RPM change seems to leave so much margin for error.
1QuickS 05-04-2018 11:30 PM
Listening to the Colortune praise is a little humorous to me. I was touting its use when I was beginning my carburetor remanufacturing business and was roundly dismissed for using "old technology" in lieu of O2 sensors. O2 sensors are fine for analyzing on-the-road mixtures during transition and main circuit operation but idle mixtures are the domain of the Colortune.
Don't forget that idle air flow balance must be achieved before final mixture adjustments are performed.
When I test run completed carburetor projects I use a Colortune in each cylinder of my test engine which is a luxury since I do not need to shuffle them to tune individual cylinder mixtures. I do still rely on Lean Best for mixture adjustment and use the Colortunes to provide supplementary information. As a disclosure: My carburetor test engine is a one liter, three cylinder Geo Metro so engine performance during Lean Best tuning is more obvious than on a six cylinder.
