Brake Issue 1967 912/6
Hi, I'm hoping someone can help. I have a 1967 912/6 and I changed the Master Cylinder, added braided brake hoses, used PMB Calipers purchased through Pelican and added new rotors and pads. I have bled the system 7 times and the pedal still travels 3/4 of the way to the floor before catching and then no matter how hard you push the brakes won't lock up.
I pressure tested the whole system using a Motive Brake Bleeder at 10psi and it held pressure for a long time never losing it. We bled it with the Motive and the old fashioned way but still the same result. Any ideas? Thank you, Ben |
Did you check and/or reset the pushrod length?
+1 on the pushrod. Just fought through this on my FJ.
1964 Toyota Land Cruiser FJ45 1968 Porsche 912 1970 Citroen DS20 1972 Lancia Fulvia 1.3s Montecarlo |
Thank you for the replies. I didn’t check the pushrod length I just switched out the master cylinders. How do I go about doing that?
Remove floorboard, using hand, push brake pedal, watch pushrod into back of master cylinder, there needs to be a minimum clearance of 1 mm before pushrod starts to move M/C piston. Pushrod is adjustable.
| Tags |
| 1967 , bleeding brakes , brakes |
