PPI recommendations - Pleasanton, CA
Can anyone provide any recommendations for PPI in or around Pleasanton, CA? About how much should it cost? Would it be Ok to take a car to the same shop that's been servicing it the last few years for an independent inspection?
Thanks...Bruce
Old 02-24-2003, 06:28 PM
I would go with a different shop than where the car is currently being serviced. Going to the same shop is comparable to both parties in court being reprensted by the same attorney.
Old 02-24-2003, 06:42 PM
Senior Member
Bruce,
Next time you post, pls put the city in the "subject" line. You will get more people looking to help this way.
Possibly you can change it now. Click on the "edit" button on the bottom right of the screen and add a city.
Helps and gets more peoples attention if you provide more data right away.
Good luck and agree with Flat6 about using a different shop.
Joe
Old 02-24-2003, 06:45 PM
Appreciate the advice, Joe and Flat6.
Joe, I was able to change the subject, but it doesn't look like it changed it on the main page.
Old 02-24-2003, 07:12 PM
