puddy's Avatar
Help - Starter solenoid needs replacement?
My car has had this intermittent problem since last year. Previous owner wired the fuel pumps to start once the high highbeam flasher arm has been pulled back. So this is the process to start.
1 - turn key to run position
2 - pull back flasher, fuel pumps buzzzzzzzzz....
3 - turn key to start & vroom!
So the problem that is happening sometimes is that there is no vroom just silence except the fuel pumps buzzing. No click from the starter solenoid either. Fuel pumps are running fine but nothing happens when I turn the key. So I repeat the starting process about 10-12 times and finally it'll start.
Could this be symptom of a bad starter solenoid?
Cheers, Chris
1986 951
SOLD: 1975 Carrera / 965 tribute w/ 1989 3.3 turbo 8.5:1, custom Evergreen K27 7200, 964 cams, euro CIS, TEC1 dual plug, rarlyL8 headers & hooligan pipe.
Old 05-07-2018, 04:01 AM
I would put the wiring back to stock first and see what you got.
206 637 4071
Old 05-07-2018, 04:16 AM
puddy's Avatar
We checked the wiring for the fuel pump feature and refreshed all the connections, its fine.
Cheers, Chris
1986 951
Old 05-07-2018, 07:09 AM
Suggests a bad starter solenoid to me, or bad circuit from the ignition switch to the solenoid. No "click" from the solenoid tells you it is not being powered, either due to a bad circuit or the internals of the solenoid, like a stuck actuator. Be sure the voltage to the solenoid is adequate and your battery is fully charged. The way the car is wired may be drawing enough away from the starting circuit to prevent engagement of the solenoid.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 05-07-2018, 08:07 AM
76 911S Targa
Check the starter by directly running power to it with jumper cables. If the solenoid does not activate you have identified the problem.
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods.
Old 05-07-2018, 08:11 AM
puddy's Avatar
Great thanks for the tips fellas!
Cheers, Chris
1986 951
Old 05-07-2018, 09:07 AM
I bought this after my solenoid failed, saved me a whole bunch of money over buying a new starter:
https://www.ebay.com/itm/New-Solenoid-0-331-302-097-104116-003-911-287-Bosch-SSBO-7506/281232737369?hash=item417ac70459:g:9H8AAOSwyi9aCm9 Y&vxp=mtr
Pretty easy to swap too
-Jayson
1976 911S Signature Edition - 3.2SSt (JE 98mm 9.5:1 pistons, 964 Cams, Carrillo Rods, ARP Head Studs, AASCO Valvetrain, 3.2 Carrera Manifold, ID725's, B&B Headers, TS HyperGate45 Gen V, TS RacePort, BW S360, AEM Infinity 506, E85)
IG: Signature_911
Old 05-07-2018, 10:03 AM
T77911S's Avatar
use a test light.
compare the light to the battery cable at the starter to the yel wire when cranking. should be the same.
you cant use a MM for this. I MM can measure 12v and there not be enough current to pull in the starter.
if you have an aftermarket car alarm check that. (remove it).
make sure the ground strap from body to tranny is clean
same with battery connections
make sure battery is fully charged and good. take it to advance and have it tested.
fix the wiring back to original after you get this fixed.
the solenoid can be "rebuilt" if that is it. but you need to know how to solder.
let me know if interested.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 05-07-2018, 11:30 AM
puddy's Avatar
Thank guys. FWIW I have already checked ground strap and all battery connections. They're all good. I have no car alarm and no evidence of one being installed originally. I'll do some testing one night this week.
Cheers, Chris
1986 951
Old 05-07-2018, 12:02 PM
