petercory
Wiring Connections on AC Thermostat Switch
I have just replaced my original AC thermostat switch (91161312100) with the supersession (91161312101). On the original switch, a green wire w/white tracer was attached to Terminal #1 and a solid green wire was attached to Terminal 2, the terminals on the new switch are labeled as # 3 & 4; which wire goes where?
I don't think it matters. Probably works either way. Pick one or flip a coin and see how it goes.
Scott 1981 911SC Targa - Platinum Metallic |
+1
It doesn't matter as it's just an inline switch which will stop and start current to the AC clutch.
Davin '87 Carrera 3.2 '66 VW Camper '59 VW Beetle |
petercory
Thank you both for the explanation!
