-   -   Wiring Connections on AC Thermostat Switch (http://forums.pelicanparts.com/porsche-911-technical-forum/995909-wiring-connections-ac-thermostat-switch.html)
petercory 05-07-2018 05:27 PM
I have just replaced my original AC thermostat switch (91161312100) with the supersession (91161312101). On the original switch, a green wire w/white tracer was attached to Terminal #1 and a solid green wire was attached to Terminal 2, the terminals on the new switch are labeled as # 3 & 4; which wire goes where?
schoward 05-07-2018 06:43 PM
I don't think it matters. Probably works either way. Pick one or flip a coin and see how it goes.
Big Dav 05-07-2018 07:18 PM
+1
It doesn't matter as it's just an inline switch which will stop and start current to the AC clutch.
petercory 05-08-2018 10:53 AM
Thank you both for the explanation!
