Solid/Mechanical Tensioner - how tight?
Found some collapsed 930 tensioners today, lucky i had the collars fitted. Ive also got some cam/rocker leaks so going to pull the motor in a few weeks and have a good look at the top end. 71 2.2T
In the meantime i have some solid stomski tensioners to hand, my question is how tight for the chain? I can see the sprockets and chains are worn, so presumably i dont want to go too tight. Chain housings are mag too, so better watch those bolts/pins.
The only advice i have so far is set them with the motor hot and no slack in the chain.
Its a short term fix while i keep it running and driving, while the sun is out =P and i get things in order to pull the motor
Old 05-08-2018, 02:15 PM
Under the radar
Trackrash's Avatar
It's not that big of a deal to rebuild the tensioners. It's going to have to be done anyway, why not do it now?
Gordon
'71 911 Coupe 3,0L outlawed
Old 05-08-2018, 04:31 PM
DanielDudley's Avatar
Set them wrong, and you can wear out your intermediate shaft bearings, the result of which is low hot oil pressure. I don't like them in general, having had that experience.
Old 05-08-2018, 04:33 PM
Vintage Owner
Jack Stands's Avatar
I’d just rebuild your tensioners and reinstall them (or convert to the oil-fed tensioners). If solid tensioners were appropriate, Porsche wouldn’t have spent all the time and money developing the tensioners. I believe they were really meant for racecars that are being continually serviced.
84 Targa (sold)
70 914-6 (sold)
73 914-6 2.7 conversion (sold)
75 GMC Motorhome (sold)
2016 Cayenne
Old 05-08-2018, 06:17 PM
Formerly known as Syzygy
Canada Kev's Avatar
Or the hydraulic ones were used to stop an expensive engine from grenading when the too often situation of a mechanical tensioner failing. In this case the OP had the collars to stop a catastrophic end to his failed tensioner.
Hydraulic tensioners can still fail.
Kevin
Old 05-08-2018, 06:42 PM
Ah yes, I have the rebuild kits to hand, I just forgot to order the main spring which dosent come with it.
At the moment I'm looking at other things, like making sure I know where all the oil leaks exactly are before I pull the motor.
Good thought on the ims, with a too tight chain.
With a fully bleed 930 tensioner (or pressure fed) how much should the tensioner plunger move during normal operation (I.e in use)
2mm or so, or more like 5 to 10?
The workshop manual has a test, where a weight is placed on top of the plunger and movement of 10mm over 10 minutes, is a defective tensioner
Old 05-09-2018, 02:51 AM
I pulled out the tensioner and idler arm. It has the later idler arm, but I am surprised to see someone put 2 shims behind it, as i understand it they are designed to float left and right so the chain will centre them? I should refit without the idler without the two shims behind right?
A porsche technical bulletien, says the later idler arms should not be used with the earlier 930 tensioner (049) and i must change to the 053?
My tensioner is 930.105.501.0R, so neither of these numbers...and I have a 901 tensioner on the other side, which looks identical to the 930.105.501.0R, i'll pull it out and photograph in a minute
See pics
Old 05-10-2018, 03:51 AM
This the right side, 901 tensioner, okay with the later idler arm?
Old 05-10-2018, 04:08 AM
Old 05-10-2018, 04:12 AM
