-   -   Problem: Fog light conversion to LED (http://forums.pelicanparts.com/porsche-911-technical-forum/996201-problem-fog-light-conversion-led.html)
damntall 05-10-2018 11:01 AM
Hi folks,
I'm new here! Sorta. :-) Anyway...
I'm attempting to convert the fog lights in my '89 911 to LED, but the back heatsink and housing of the LED bulb assembly sticks out a lot further than the well-set-in halogen factory bulb.
Thing is, I'm told that the plate at the back of the fog light assembly cavity (shown in the photo in red) is removable, and may thus provide an empty hole through which that assembly can poke, enabling its use. So my questions are these:
1. Is that plate removable?
2. If yes, how do I do it?? I have no clue how to even get at any fasteners that might be holding it in.
Any thoughts?
http://forums.pelicanparts.com/uploa...1525974846.jpg
Bryan
In-A-Band-Jose, CA
'89 Silver Anniversary Carrera coupe in Satin Black Metallic ("8T9")
'03 Boxster S ("Voxster")
lpsalsaman 05-10-2018 11:26 AM
That plate is part of the assembly, behind it is the bolt that connects to the body and keeps the fog light in place.
http://forums.pelicanparts.com/uploa...1525976437.jpg
Are there any other H3 LED type bulbs that could be a bit less longer? Definitely don't want to mess with the assembly's bolt bracket unless you can rig it to stay in place without it.
damntall 05-10-2018 11:31 AM
Thanks! That's what I needed to know! I'll keep looking for alternative LED solutions for the fogs. And if anyone has suggestions, I'm open to that, too!
lpsalsaman 05-11-2018 03:56 PM
I did a quick search comparing the regular H3's to some of the LED replacements and there are several that seem to be just a bit bigger than the originals. Just keep looking, you'll find them. Good luck!
Koizumi 05-11-2018 04:56 PM
If you do find an led h3 that fits sans surgery, please post here at let us know. I’m tired of changing h3 filament bulbs every few months! I’d sure like led h3 bulbs to keep things cooler, I’ve wired my fogs as daytime driving lights.
Jack Stands 05-11-2018 06:41 PM
They’d probably be better as DRLs than fog lights. I’m trying to do the same on my 914-6 as it uses a very strange bulb.
Lyle O 05-11-2018 09:00 PM
I found an H3 that fit pretty well, but I was disappointed at the light output. It was not as bright as the halogen at all. However, the color was much more cool, and matched well with my H4 LED head lamps (which really rock), so I kept them installed. I agree they would be better as DRLs, as front fog lights on these cars don't do much anyhow. If someone can post about an H3 replacement LED bulb that has high output (better than halogen) it would be interesting....
lpsalsaman 05-12-2018 04:32 AM
Same here, I wired mine a long while back like you to help my old sealed beams. I then got some Cibies H4's and it's much better. But definitely good H3's will be great to have!
964TargaC2 05-12-2018 07:20 AM
I used HID conversion, 3000k (yellow light), for my fog lights and am happy with the result, they are fog lights not driving lights..
911pcars 05-13-2018 03:55 PM
Find and ID the existing bulb number, then find it's equivalent in an LED form factor.
Sherwood
Koizumi 05-13-2018 04:07 PM
Sherwood
The trouble is that the equivalent LEDs that I’ve encountered are larger size-wise in length than the H3 bulb. In other words, they will not fit in the shallow foglight housing. LED equivalents vary in size, so I’m sure there is one that will fit Oem 911 fogs... But I have yet to fine one that does.
Again, if anyone knows of one that fits the housing, let us know [emoji41][emoji482]
spoke 05-13-2018 07:34 PM
Originally Posted by damntall (Post 10032236)
Hi folks,
What LED light are you trying to install? Do you have a part number?
lpsalsaman 05-14-2018 06:16 AM
The H3's height are 32.0 MM I believe, so you have to find one that is the same size to make it work. On our fog light housing's it seems that anything above that measurement will be a problem. I have seen pics of different brand H3 LED's and there a few that seem to match that size. The link below shows LED H3's for a Mustang but the size seems to be close to the original halogen ones that we use. Goo luck!
https://www.cjponyparts.com/diode-dynamics-fog-light-bulb-led-h3-cool-white-pair-gt-1987-1993-cobra-1993/p/BULBH3LED/
tirwin 05-14-2018 06:51 AM
I tried the same thing with the fog lights on my SC. The LEDs are too deep. I tried taking a nylon bushing and making a spacer so that the LED was at the proper position in the housing. I ran into another problem that I can’t remember but I gave up on the idea.
I came to the conclusion that the fog lights are basically worthless. I would rather have an LED panel and wire them up as a DRL.
I did some searching for different DRLs that I could mount so I gave up an ordered a pair of Hella amber fogs for now.
Maybe one of the people that are building LED kits will come up with a solution. *hint hint*
ADDvanced 05-14-2018 07:02 AM
Don't do it. LED replacement bulbs provide inferior illumination. The only type of LED lighting that is acceptable is something that comes FACTORY on cars. Retrofitting LEDs for illumination = hot spots, tons of marketing claims that have no basis in reality, and the fact that LEDs gradually get more blue as they age and the phosphorus coating wears off due to heat.
If you want more light, get an HID upgrade kit from ddmtuning. Will be $40-60 somewhere.
tirwin 05-14-2018 08:07 AM
HIDs for fog lights?
ADDvanced 05-14-2018 08:10 AM
Sure. They are just H3 bulbs.
DDM Tuning: HID and LED Lighting
Click H3. Click wattage. Done. Way more lumens than you had previously.
tirwin 05-14-2018 02:28 PM
Never seen the HID H3 option before. Thanks. Looks interesting.
Koizumi 05-14-2018 02:48 PM
Isn’t one of the issues with our foglight housings: heat?
Every HID conversion I’ve done have run hot! 35w is even hot. Now it’s nothing as hot as HIR bulbs but...
I’m looking for non-ballast installs. No HIDs. Cooler LED bulbs would be ideal for me. Just for DRL purposes. The fogs for fogsakes are not vey good to begin with [emoji119]
