-   -   How do you open the DME box? (http://forums.pelicanparts.com/porsche-911-technical-forum/99627-how-do-you-open-dme-box.html)
pbs911 02-25-2003 07:39 AM
I need to change out my chip. I watched Ingo open the DME box but now I can't get it. I have lifted the tabs and removed the circuit boards from the metal container. I understand there are two tabs near the plug that must be lifted but I cannot get the top circuit board to slide out. AM I missing something?
Tim Polzin 02-25-2003 07:50 AM
Paul:
On the side opposite the plug there are several plastic posts separating the two boards. They just snap apart, then the top digital board can slide out and open like a book.
Tim
Wil Ferch 02-25-2003 10:15 AM
Not totally accurate....
First..as you know...you need to bend the 10 ,or so, bottom metal tabs.
Then, you look for the two posts ( as was said) and separate them axially from themselves by wedging something like a small screwdriver blade along the post.
BUT now...in order to separate one board from the other...( like folding open a book), there are two push tabs that are in slots within one board, on the opposite side where the ribbon ( "hinge" for the two boards) is. Again, carefully use a small screwdriver blade to *gently* push down on these tabs one at a time, while pulling back one of the two boards...now the two boards should separate and fold open...
(Easier said with a picture ...:( )
---Wil Ferch
Tim Polzin 02-25-2003 12:58 PM
Wil, did you say "Say it with a picture".... here they are:
The second picture shows the clips Wil was referring to. If you lift the board a bit, it should slip by the clips, otherwise do as Wil said.
http://forums.pelicanparts.com/uploads/dmeclip1.jpg http://forums.pelicanparts.com/uploads/dmeclips1.jpg
Tim
Wil Ferch 02-25-2003 01:51 PM
Thanks, Tim...
In re-reading my post...I may have started-off a bit strong...but see you didn't take it the wrong way :)
Thanks for the pics...exactly what I was trying to portray !!
--Wil Ferch
