G50 Torsion bar tube foam blocks?
Greetings;
Upon removing the AC lines from and through the gap between the rear torsion bar tubes and the rear seat body area, I also removed a foam rubber block from each side. See photo of my ‘87 Carrera. I am wondering if the whole gap between the front of the torsion tubes and the body should be plugged with similar foam to prevent hot air recycling. Thanks! Donnie Stanford ![]() ![]() |
I recalled seeing something about that foam - I think this was it below. Seems like it may be more for moisture control.
Torsion bar foam seal
Dan '87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip Venetian Blue |
