Question AdJusting rocker shaft
How do you readjust or align the rocker shaft. I have search the archives to find how to do so and wasn't successful.
I'm planning to take the rocker out of the cam housing to check the inside bushing in the rocker.
Thanks 4 help
78 911SC
Old 02-24-2003, 11:28 PM
All I do is center the shaft between the two ends and torque it down. There isn't any clocking. Suggest you install the rocker shaft seals, 2 on each shaft to keep them from seeping oil.
Keith
Keith
Drive Hard and Fast
1991 Carrera 2 Targa
1972 911T Coupe
1971 914
Old 02-25-2003, 06:05 AM
Super Moderator
cstreit's Avatar
Well remember that the flanges that the rockers mount thru are different widths, to the shaft will be centered under the rocker arm, not between the flanges... On my car they were installed with the shaft just peeking out of the thinner flange.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 02-25-2003, 06:07 AM
Also the torque on them after you remove them is slightly higher than spec. I can't remember what is recommeded here but hopefully John Walker or Warren will comment here.
Dan O
84' 3.2 Targa
Dan O
84' 3.2 Targa
Old 02-25-2003, 06:44 AM
Super Moderator
cstreit's Avatar
http://www.competitioneng.com/WaltsPage.htm
Recommends 20 ft/lbs on used rockers. Dry installation...
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 02-25-2003, 08:10 AM
it was also pointed out here not to let the rocker shaft spin in it's bore.
72 911t grey/black mine
74 914 2.0 black/ tan hers
02 g500 black/black womanproof
01 f250 psd dirty the mule
60 correct craft starflite cool
69 correct craft torino hauls butt
72 correct craft ski nautique fun
66 vw 1500s will finish someday
Old 02-25-2003, 09:32 AM
