-   -   DUMB QUESTION #4: Secret Hidden Button (http://forums.pelicanparts.com/porsche-911-technical-forum/996678-dumb-question-4-secret-hidden-button.html)
thefaculty 05-15-2018 07:17 PM
Ok.... this one has me stumped!
I found this while crawling around under the dash on a Tuesday night (as you do) and this was attached to a bunch of wires behind the dash right above the centre consul that houses the 2 dial air-conditioning controls. Anyone got any idea what it does? I'm guessing perhaps its something to do with the air con that the PO never used and says is disconnected. Any ideas greatly appreciated! :)
cheers
dKhttp://forums.pelicanparts.com/uploa...1526437015.JPG
DaddyGlenn 05-15-2018 07:19 PM
follow the wires...
Bill Douglas 05-15-2018 07:25 PM
Don't press it while you are in the drivers seat (ejector seat button :) )
thefaculty 05-15-2018 07:26 PM
Originally Posted by DaddyGlenn (Post 10038653)
follow the wires...
lol - Thanks DaddyGlenn, do I take the blue or red pill while I do that? :eek:
DaddyGlenn 05-15-2018 07:32 PM
saw your other posts ... maybe related to your cruise control stalk? just guessing as they booth look like after market additions.
thefaculty 05-15-2018 07:36 PM
That kinda makes sense! Cheers. I'll start pressing things tomorrow and see what happens! ;) From what I read cruise control seems like a total waster of grams on this car and not sure I'd ever use it anyway. Once I figure it out perhaps it's best gone!
Thanks!!!
Jack Stands 05-15-2018 07:37 PM
Definitely aftermarket, but you’ll have to follow the wires. Perhaps a anti theft system?
RSBob 05-15-2018 07:48 PM
You weren’t supposed to find that.
pavegeno 05-16-2018 04:11 AM
I have a switch like that on my 88 Cab. I put it in to turn on the right front oil cooler electric fan manually. The fan will still come on automatically when the thermostat senses high oil temperature as well. I was troubleshooting an oil temp problem that turned out to be the engine-mounted oil cooler. I still turn it on early on hot days to keep the temps down some when I have my A/C blowing.
It could be just about anything though. Most likely an ejection seat so please be careful.
86 ssinit 05-16-2018 04:37 PM
Yeah your going to have to press it and if that does nothing follow the wires. It’s aftermarket and could be anything from a fog light switch to a engine cut off. So press it when parked.
DaddyGlenn 05-22-2018 03:48 AM
Did you find out what it goes to?
thefaculty 05-22-2018 04:16 AM
No idea. I am waiting for a new AC fan belt, relay and fuse to arrive so that I can connect that up (PO disconnected them but did not remove them so I want t o see if they still work before deleting) and perhaps it's something to do with that because I can't think what else it might be. It used to be screwed to the underside of the dash at some point in time.
Mike Andrew 05-22-2018 06:14 AM
Power antenna switch?
Have you ordered Bentley and 101 Projects yet?
