Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > Porsche 911 Technical Forum
rennline bumper shocks?
Hi gents
Can someone confirm that the rennline bumper shocks offer the same weight savings (approx) as the euro ones. Looking to save weight by replacing the US spec shocks.
Is it worth doing front and rear? These rennline shocks are much cheaper than the euro units??
Thanks in advance
Old 05-16-2018, 05:28 AM
A bumper shock's purpose is to raise the spring rate at full bump. Personally, I'd look for bumper shocks that fit suspension design / spring rate around the intended use of the car (significantly lowered / track car) rather than to lower weight. Koni designed them for race cars many decades ago, and (AFAIK) they still make them in different effective spring rates. I've used them on my formula cars.
Current: 40th Anniversary 911, Cayman
Old: 68 912, 67 911, #2 67 911, 66 911, 70 911S, 72 914, 89 944TS, 79 928, 83 928, 72 911T (2.7RS), 89 964 C4, 66 912, 70 911E, 84 911 coupe, 1973 914/6 with 993 engine, 7 other formula cars (professionally licensed).
Old 05-16-2018, 07:08 AM
I believe the OP is referring to the shocks/tubes in the actual bumpers.
Ass-engine Nazi slot car -- PJ O'Rourke
Old 05-16-2018, 07:10 AM
Registered Minimalist
75 911s's Avatar
When you say "euro units" do you mean Porsche brand euro crush tubes? I can't answer whether they are the same weight as the official Porsche tube. I don't see how they could possibly weigh much more as the Rennline units are extremely light and well built. I bought both the front and rear impact tubes. The difference in the crush tube vs the hydraulic US impact tube is dramatic.
One thing I noticed was that on my car, I had to drill the ends out of the impact tube mount on the car. Both ends of the Euro tubes are larger thread. The bumper side studs will fit through the bumper, but you need new hardware as the studs are larger. As I mentioned, the chassis end of the tube mounts on the car need to be drilled out larger to accommodate the larger crush tube stud and you will need new washers and lock-nuts.
Duane
http://forums.pelicanparts.com/porsche-911-technical-forum/878569-born-75-me-my-new-911s.html
Old 05-16-2018, 07:28 AM
I recently replaced MY84 rear impact bumber shocks with the Rennline units - spoke to Rennline about weight of their units (approx 1lb each) before ordering. I do not know what the Euro versions weigh but if steel constructed then should be about the weight as RL. I did not weigh the RLs before install but are considerably lighter than OEMs. I’ll try to weigh the OEMs and post. Additionally, I had no fitment issues as it was plug and play on my install
If you say you are going to do something: do it.
If you give your word: keep it.
Old 05-16-2018, 07:33 AM
75 911s's Avatar
Originally Posted by Helix8 View Post
I recently replaced MY84 ... Additionally, I had no fitment issues as it was plug and play on my install
That's interesting. Here's a side by side of my 75 original hydrualic US impact shock vs the rennline. You can see the rennline is like a m14 and the original is m12.
You can see the other end in the shock above. The rennline bumper through studs are m10 vs m8 on the us hydrualic shocks.
I guess they went bigger for the SC and carrera? I always thought the shocks were all the same.
Duane
Old 05-16-2018, 09:21 AM
Jonny042's Avatar
I bought a complete set of these for my lightweight 3.2 Carrera project - havent fit them yet but did compare them to the stock units from an 85:
Rear bumper shocks:
Note the studs on the two sets do match in size. The weight savings isn't huge, but I for one want to maintain some semblance of bumper integrity on my car - no fiberglass for me! So every pound counts.
I briefly considered going with a fiberglass bumper blade but the stock one is very strong for it's weight - only 16 pounds. Don't believe the fiberglass suppliers claimof "Saves 18 pounds!".
87 Coupe - The Driver
78 Backdate - The Project http://forums.pelicanparts.com/porsche-911-technical-forum/979976-project-heavy-metal-all-steel-classic-remastered.html
85 Coupe - The AX Beater
Old 05-16-2018, 04:00 PM
Thanks gents
Ive just realised these are a crush tube? so not a shock as such. Any impact is a one time use for these...??
I think Ill order 4
Old 05-17-2018, 01:17 AM
Flojo's Avatar
... someone drilled holes in the tubes...
Regards, Flo
79 SC - Frankfurt, Germany
visit me on www.facebook.com/911garage
Old 05-17-2018, 10:31 AM
I bet the blade with bumperettes and accordions, and the smaller quarter panel extensions are heavy together.
Old 05-17-2018, 11:34 AM
75 911s's Avatar
I get close to 9lbs for the front shocks. So if the Rennline are 1lb each, then by my calculations that's roughly 7lb savings for just the front end.
Duane
Old 05-17-2018, 01:45 PM
Duane
Helpful as always mate
Thanks all. I'm heading to the US next month (from Oz) and I plan on stuffing my suitcase with as much gear as I can!!
Old 05-17-2018, 03:13 PM
Can you explain? 6lbs seems low for oem bumper shocks. Are you saying these 6lb shocks were drilled out to make them lighter? I thought oem us shocks were more like 9lbs. Thanks!
1981 Euro SC (3.2L); 2004 911 GT3; 2005 Gallardo (RWD, 6-speed); 1995 M3 track car (Euro motor). Cadillac ELR (Daily Hybrid); 2016 Escalade (wife's ride).
Old 05-17-2018, 03:30 PM
Jonny042's Avatar
I think maybe he was suggesting it could be done to lighten the rennline/euro mounts even more.
Old 06-09-2018, 04:25 AM
This is my plan. Drill a hole in each of the front shocks, empty out the fluid, compress them, set screw to keep them where I want them, modify bumper and/or accordions, swap the stock SC smile for one from a 964.
I've seen a few bumper tuck threads and while not as prevalent among 911 owners as it is with the E30 crowd I think it looks good.
_______________________________
1982 911 SC 229,000mi and counting
Old 06-09-2018, 10:37 AM
madcorgi's Avatar
I'll be interested in seeing how this works out--I'll be deciding on bumpers pretty soon myself.
Old 06-09-2018, 12:54 PM
