Yes, new cap, rotor , plugs, wires, fuel filter from pelican. Also I did check the spark. What about the coil? Maybe it is not as strong anymore. But car does start right up.
Old 05-18-2018, 06:27 AM
I will go back and check things again today
Old 05-18-2018, 06:29 AM
After finding my intake gasket leak on the #4 cylinder, I replaced ALL the intake gaskets even though I didn't identify a leak on the 1-3 side. I would highly suggest you go back in and replace those as well. Once I pulled the 1-3 manifold I had an obviously compromised gasket on the #3 cylinder as well.
Your compression numbers are within 7%, which is generally acceptable. I wouldn't have a huge concern with the engine mechanical at this point.
If you had a confirmed leak on the #1 I have little faith the gasket are in any kind of reasonable condition, even if you re-torqued the mounting bolt I still consider them as suspect. Worst case scenario you'll at least have confirmed good intake gaskets.
Old 05-18-2018, 08:07 AM
I just double checked spark. Bought a cheap online plug tester from harbor freight and I have good consistency with plug and spark. Double checked for a leak in 1-3 intake gaskets again. So sign of a leak. So now after everything, Iím thinking fuel. I did install a new injector, Maybe it is defective. Before I installed it I checked that the plug was a strong 12 v plus. And it was. Not sure how to check for a spray since all are installed in the rail.
Old 05-18-2018, 09:10 AM
New-ish 911SC Targa Owner
pampadori's Avatar
swap injector with another cylinder and see if symptom follows it. You said you confirmed it was squirting fuel so I'm at a loss. You checked all the things it could be.
Did you try swapping plug wires with another cylinder that will reach?
'83 Targa freshened 3.0 with 930/52 case and ARP and Raceware hardware - AEM Infinity 506, Triumph T595 throttle bodies, B&B headers.
'95 W124 E320 wagon on Monoblocks
'05 E500 wagon in minty cond
'13 Volvo XC60 (hers)
Old 05-18-2018, 09:22 AM
Well I did two things with the new injector, I put stethoscope on injector and it is clicking fine. Also, when I first installed the new injector it was not seated all the way at first and gas was coming out all over the bottom seal area until I seated it better . I just pulled off number one plug wire again and no change in the way it runs. Pull off any of the others, rpm’s go way down. I guess I’ll swap injectors
Old 05-18-2018, 09:43 AM
Flat Six
Flat Six's Avatar
Nick: a longshot and pretty rare, but you might have a bad spark plug in #1. Easy to check; swap plugs w/another cylinder. This fault wouldn't show up w/the spark tester you used.
Had this happen to me in an MG Midget many, many moons ago. Drove me batty (having Lucas electrics didn't help either :-p).
Good luck.
1985 Carrera 3.2
2013 Audi Q5 2.0T / 2005 BMW 325ci
Gone but missed: 2007 Audi A4 Avant Quattro / 1990 944S2 Cab / 1984 944 / 1990 Audi 80 Quattro / 1987 Audi 4000 Quattro / 1987 BMW 325is
Old 05-18-2018, 11:23 AM
Thanks! I’ll swap!
Old 05-18-2018, 12:07 PM
Checking fuel injectors now. I hate those suckers in the drivers side .
Old 05-18-2018, 12:09 PM
I just took back the injector that I just bought, the store is getting me another. I checked fuel line to number 1, it is clear .
Old 05-18-2018, 02:30 PM
Did you actually swap the injjector into another cylinder location to see if the miss followed the injector? I see you confirmed that fuel is getting to the injector, but can't tell if you confirmed that the injector itself was or wasn't providing fuel to the cylinder.
Old 05-19-2018, 08:07 AM
bennysc1
When was the last time you replaced the fuel filter? Might be time to change that filter. I did it to my car and ran much better
Old 05-19-2018, 08:23 AM
Did you try this ^^? Could be a bad plug wire. When you saw spark while testing with a grounded plug, was it a reddish spark or a bright blue
lightning like spark. Reddish spark won't fire under compression!
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 05-19-2018, 11:35 AM
Changed cylinder number 1 with a new injector and replaced new ngk plug with a slightly hotter ngk plug because I have lower compression in that cylinder. Dead cylinder came alive!!! Car will live another day. Just finished test run. Holy smokes!! So now car starts with good cold start, ( intake gaskets), has 800 idle and drives fine. Sorry for my 400 posts. Was just aggravating for two months .
Old 05-23-2018, 03:59 PM
carreradpt's Avatar
So if post 3 was followed , plug /injector, this would have been solved back then. Just saying.
Dan T
'85 Carrera
Dansk premuff/sport muffler
7's and 9's, Steve W chip
Kuehl AC and fresh top end
Old 05-23-2018, 05:12 PM
Flat Six
Flat Six's Avatar
Congrats, Nick -- way to stick with it and glad it's fixed.
1985 Carrera 3.2
Old 05-23-2018, 05:39 PM
Thanks! Dan, the thing is I thought I had it fixed several times. But the misfire kept coming back.
Old 05-23-2018, 06:17 PM
