Other places for a vacuum leak?
I have a bad misfire. I have found, checked, replaced all leaking parts including intake gaskets, behind throttle body, hoses next to oil fill cap, hoses up way to the left of throttle body. fuel injectors are tight. Oil cap is tight. Nothing seems to be leaking topside using the starting fluid method. I notice now after all the work, engine no longer lowers RPM's when I remove the oil cap. But car cold starts fine and has an 800 idle. I need more ideas where to look for vacuum leaks. Holy Cow!
Fleabit peanut monkey
Brake booster hose. IIRC JW mentioned he found a leak under the body as it heads towards the front.
1981 911SC Targa Last edited by Bob Kontak; 05-14-2018 at 04:29 PM.. |
Thanks Bob, I’ll take a look. This mis is killing me!
Dan '87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip Venetian Blue Last edited by steely; 05-14-2018 at 07:02 PM.. |
Did you actually physically remove the fuel injector sleeves in each of the manifolds, clean, replace with new and re-peen them? If you did not, you still have six leaks...each injector has two o-rings, one to seal the sleeve and the other on the injector...
Rex 1975 911s and 2012 Range Rover Sport HSE 1995 BMW R1100RS, 1948 Harley FL |
Well, I thought I had a bad injector on cylinder number 1. I just replaced that one injector because I really thought that was the bad cylinder. When I pulled out the number 1 plug wire there was no change the way the motor ran . I did have spark. I did a test to see if the extra injector I had would make a difference. It did not. I checked with my meter, I do have 12 volts to that injector.
Dumb question, What is a injector sleeve? My 3.2 Just has injectors. Are you taking about the orings ? Yes, there is one in the top and bottom on my injectors.
Also check the cork gasket around the sender unit for the oil level on the oil tank.
In your previous thread you stated. "Thanks for the info. I did check the drivers side intake for vacuum leaks and it did have some . So I tighten that side up and stopped the leaks . The passenger side was not so easy . Could not stop the vacuum leak so I replaced the intake gaskets on that side. All is well in the vacuum department now! When I get time (mother’s day). I will change out the injector."
If you are still having an issue with dropped cylinders on the left bank I would consider going back in and actually replacing those intake gaskets as well. If you had a noticeable leak and just tightened the manifold bolts it is likely the gaskets have already degraded and are in poor shape. If you have an infrared temp gauge, you can check exhaust runner temp to determine which cylinders aren't heating up (missing) as fast as the others. |
You can run a compression test on a suspect cylinder to see if a burnt valve seat or the like but that is not a routine occurrence for a hobby car.
1981 911SC Targa |
1981 911SC Targa |
