will 3.2 heat exchangers fit on a '74 motor?
I have a complete exhaust from a 3.2 and someone interested in putting it on their '74. Aside from the hoses for the heat from the engine side, are there any other issues to be concerned with? Length of the exhaust header studs and interference with any oil pipes would be my two other concerns?
Thanks,
Bill
Old 05-20-2018, 09:13 AM
You ll need long studs installed and remove the head inserts on the Carrera exhaust.
From your year you’ll need everything to the muffler and a different clutch lever to clear the crossover pipe. Use the SC style air connector for heat.
Bruce
Old 05-20-2018, 10:48 AM
Bruce
Thanks Bruce!
Bill
Old 05-21-2018, 06:27 AM
Vintage Owner
Jack Stands's Avatar
If you do the conversion, I do have one of the appropriate clutch levers. However, the ‘74 exhaust system is nicer than the later style and many folks backdate rather than the other way around.
84 Targa (sold)
70 914-6 (sold)
73 914-6 2.7 conversion (sold)
75 GMC Motorhome (sold)
2016 Cayenne
Old 05-21-2018, 07:48 AM
