				 Alternator ?'s
			Hello!
 The alternator on my 72E has stripped rotor threads.  I replaced the entire assembly with an alternator from a 73T.  Now the warning light somes on until about 3k rpm's.  I took the assembly back out to test per the workshop manuals.  I found the resistance between the slip rings to be around 4.2.  The spec is within 4.5 - 6.5.  I assume this is the low voltage problem??  Also, I have an alternator from a 70 and a 71.  Would either of these work?  I heard something about the regulator has to be matched to the alternator.
 Thanks!
 BK
