-   -   Fuze problem? Bad ignition switch? (http://forums.pelicanparts.com/porsche-911-technical-forum/997181-fuze-problem-bad-ignition-switch.html)
Larrybrook 05-21-2018 09:49 AM
This just happened...I haven't driven the car for a couple of weeks, had it on the battery tender. went to start it. everything normal, the humming noise that I assume is the fuel pump , she turned over for about 3 seconds, and sputtered as usual, turned the key to off, tried again and then dead. no more humming, no headlights, stereo...nothing. I pulled the battery and am cleaning all the connections, looked at the fuze panel and don't anything blown. Could it be the ignition switch? How do I "Hot Wire" the car?
proporsche 05-21-2018 09:51 AM
Hi ,Do you have the lights on the gauges with the key on?
Ivan
Larrybrook 05-21-2018 10:26 AM
Sorry folks...false alarm. i cleaned all the battery connections, put it together and she fired right up!! I don't know why i always panic and think the worst???
proporsche 05-21-2018 10:29 AM
time for a beer now....;-)
