-   -   Part Identification (http://forums.pelicanparts.com/porsche-911-technical-forum/997220-part-identification.html)
springer12 05-21-2018 02:14 PM
Part Identification
I recently got parts back from having a ton of stuff plated and have a few that I can't seem to identify. I've letter labeled them to identify them in the image. Any help would be appreciated. http://forums.pelicanparts.com/uploa...1526937175.jpg
proporsche 05-21-2018 02:24 PM
hi i assume it is all from 911 Carrera 1984 and up?
A.fuel bracket left hand side on engine
B.door frame bracket for Allen bolt which goes on top of E.
C.i do not recognized this one
D.camshaft oil line fitting on each side of the engine where the trough bolt goes ..but i do not see the details of it.
E .as mentioned above..it is your door window frame bracket which gives you the angle frame adjustment possibility.
F..another fuel line bracket
Ivan
Flat6pac 05-21-2018 02:27 PM
A is the support for airbox above the throttle console
D is the adaptor for oil line to cam carrierB and E are clips to support the injection lines
F looks like the Carrera harness support under the air flow sensor
Bruce
proporsche 05-21-2018 02:37 PM
Sorry Bruce you might be wrong on the B.and E..look at 8 and 9
https://www.design911.com/uploads/di..._04_804-15.jpg
and yes F is the support bracket for AMF from the little rubber mount
Ivan
springer12 05-21-2018 03:14 PM
Hi,
Thanks for the help. It's a 78 911SC. My windows are super slow up/down so I'm guessing this is the culprit.
Oddly the oil line fitting must be an extra I have as I have one on each side of the engine already. https://www.dropbox.com/s/pcuwgfdns0..._5548.JPG?dl=0
The A bracket looks to fit here but the previous owner seems to have filled the whole. Reaching around the back side of it I can feel the back end of a bolt so I'll have to drill it out. https://www.dropbox.com/s/ue9dbwqztp..._5549.JPG?dl=0
https://www.dropbox.com/s/ue9dbwqztp9jjgd/IMG_5549.JPG?dl=0
https://www.dropbox.com/s/pcuwgfdns00m3c7/IMG_5548.JPG?dl=0
springer12 05-23-2018 03:04 PM
What's this part?
Anyone know what this part is for? http://forums.pelicanparts.com/uploa...1527112954.JPG
jrbennett 05-23-2018 09:31 PM
Originally Posted by springer12 (Post 10047927)
reinforcement plate for door mirror mount, I think that one is from the passenger side
springer12 05-24-2018 09:27 AM
I thought it went in the door based on the contour... thanks for the help jrbennett!
