Here's the post. Backdated Heat Tech Article And here's a pic of the '79 before we did the work, and after.
1983 SC Coupe Chiffon White 3.0 rebuilt by me 9.5:1 964 Cams. SSI's. Backdated heat. KEP sports clutch. |
Jameel- great backdate post, it's been a huge help. I had all the major pieces but the part numbers for the fasteners made life easier.
I removed the last of my AC components last week. Looks like a total of almost 70lbs.
_______________________________ 1982 911 SC 240,000mi and counting Last edited by QueWhy; 06-16-2018 at 09:02 AM.. |
Still here
the reason for the blower was to defrost / defog the windshield at idle ( safety add ) when the car was cold as there was not enough pushed. I really doubt its needed.
Mine is there but is gutted ( I actually like the original look and prefer it over backdated look )
1976 Yamaha XS360 ( Beats Walkin') 1978 911 SC Targa ( Yamaha Support Vehicle ) 2006 Audi A4 2.0T (Porsche Support Vehicle ) 2014 Audi A4 2.0T Technik (Audi Support Vehicle) |
Personally, I like A/C...In a 911 or a Ford. From an old thread:
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender |
82 911 SC - Ancora Imparo
OP, were these the parts you purchased? Why are there so many parts for the right side? For some reason I thought it was just one duct for each side.
SEVENT9
The ducts cost me $195.95 from our host. You'll also need some 2.5" sceet hosing which I got from Aircraft Spruce. I got 4' and had about a foot left over. I wouldn't buy 3' though - allow yourself a little room for error. All in all the whole job cost about $250 and took about 1.5hrs if you were to do in one sitting (which I didn't because of work - I was literally pulling parts in between client sessions!) You can check it out on the build thread I started recently for my '79 SC: '79 OUTLAW // Build Thread Hope that helps!!
- - - - SEVENT9 '79 SC Black: My first 911 & my birth year!! ![]() http://forums.pelicanparts.com/porsche-911-technical-forum/1000359-79-outlaw-build-thread.html Last edited by thefaculty; 07-20-2018 at 07:30 PM.. |
Perfect- thanks very much. No additional hardware/bolts etc? Just the ducts and the SCEET?
TF... sent you PM.
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. |
A/C yes or no
Hi The faculty,
I would leave it for about six months to a year,then make a decision. funny over time some times you change your thinking, and you never know you may decide to sell it later to upgrade, and to some one that would love it to have its original A/C, that lives in a warmer area. Pmax i know what you mean Nor Cal,Bay area, but you only have to drive back towards Vallejo 30 miles ,and the temp goes up 25 - 30 degress i did that for years, 15 years ago. regards. |
Does not cost that much to repair an original system. I converted to 134, bought rebuilt compressor on eBay, new dryer, expansion valve from pelican, gauges and pump from harbor freight , 134 from Walmart
Ester oil from auto zone. Cost me about $400 to get my original 85 Carrera up and running for two years now. Not great but 55 degrees average on a warm San Diego day. Does not cost $2000 to make these systems work. |
Oh, also bought new thermostat switch from griff. Got it all going for cheap!!! I also bought an oring kit and replaced those as I went along. I just did some math, I think was closer to $450. Still not bad.
Of course to depends on how you define "working". 55 degrees is about normal for the factory air...but it is worthless/useless for very many people. Vent temps over the mid 30's will not result in a comfortable car in the summer in much of the US. The low amount of airflow/poor vents, large amount of glass (especially in a targa) makes it useless. I can get 55 agree vent temps from my original, factory system in my '89 any time...but it is useless. It will not even cool a car down in the shade/at night when the temps and humidity is high. The 32 degrees in my targa with a full cup solution from Griffiths did the job and cooled the car down (even then, it could have done better...was not comparable to a modern system.
If I was going to spend $45,000 on a 911 I would want the AC installed and working. Even with our crappy AC systems.
