Bill Verburg's Avatar
Originally Posted by jesse16 View Post
i'm a fan of keeping it simple. Warm oil for speed and a tube snaked in through the wheel well. Oil goes in quick with a few squeezes/gravity with minimum mess. I don't have a lift but i usually put the car on a few wooden blocks so i can get my arm in there easier. Sometimes will jack it and put on stands reasonably level as that's pretty quick also. How often do you change, i'm every 2 or 3 years or 15-20k miles. Never looks bad coming out.
+1
Bill Verburg
Old 05-25-2018, 05:19 AM
Originally Posted by 82 SC View Post
This will solve your problems. I just ordered it https://www.northerntool.com/shop/tools/product_200622686_200622686
Wow, I am a tool junkie, but that is overkill for me. I do an transmission oil change regularly. I hate it as much as Jack. It is a stinky, messy job. There is always so much waste in the hoses and pumps and mess to clean up. I would have to own a professional shop to want to own that one. It is nice, but overkill.
42 Year member of the Porsche Club of America
Old 05-25-2018, 06:09 AM
82 SC's Avatar
over kill is my middle name. since i have a shop and a lift and 10 cars this will make my hobbie more fun and less mess I hope! LOL! What gear oil would be good for all manual transmissions of old cars?
1982 SC "Spooky"
1961 VW Single cab truck
1966 VW Deluxe Hard top
Old 05-25-2018, 06:35 AM
I take tire off. Zip tie tubing to make sure it stays in place. Secure funnel with zip tie to something stable like a ladder or something, then pour straight from the jug
while you drink a beer
Bill
Old 05-25-2018, 06:59 AM
KTL KTL is online now
Schleprock
KTL's Avatar
Send a message via Yahoo to KTL
If you do decide to use an electric pump, use this fitting to connect into the fill hole
Screw Plug Adapter - Transmission Drain / Fill Plug - M22 Tapered thread to AN-08 Male By Patrick Motorsports Porsche & Mid Engine Performance Specialists
Kevin L
Present: '86 Carrera, '79 911SC widebody conversion rolling racecar shell
Past: '87 Carrera
Old 05-25-2018, 07:23 AM
3rd_gear_Ted's Avatar
Baja Ted style =
I found a used 12 vdc Toyota windshield washer tank & pump.
Fill wash fluid tank with gear oil, also used a curly small outlet hose from my dead HF air pump.
Add 12 volt battery and you can SEE the oil getting pumped out.
1980 911SC
Fiberglass Turbo Flares F&R with a 3.6L conversion
869#
AKA "Gemma"
Old 05-25-2018, 07:32 AM
Eng-o-neer
Tremelune's Avatar
My plan was heat and gravity (and maybe substituting a cut-off 2L soda bottle in place of the funnel). From this thread:
Old 05-25-2018, 09:55 AM
shoooo32's Avatar
Originally Posted by 3rd_gear_Ted View Post
Baja Ted style =
Baja Ted FTW!
How long did that Toyota pump push that gear lube before it got real hot?!?
Instagram: @shoooo32
Old 05-25-2018, 10:09 AM
82 SC's Avatar
The older i get the less hassle I look for. I did the gravity for a long time, works on some cars not on others. Pump is good but a pain if it is old and it starts to come apart or the hose keeps coming off and oil goes everywhere. Will let everyone know how my oil dispenser works out. Had a $20 off coupon and it was on sale for $135. Hope to last a life time...
1982 SC "Spooky"
Old 05-25-2018, 10:41 AM
Administrator
Jack Olsen's Avatar
Big picture, my hope is to be able to pour 3 quarts into a bucket and pump it into the transaxle without spraying anything all over or having to do any hand pumping. For a once-a-year thing, I shouldn't complain about hand pumping. But... well, I am. (I'm lazy. I don't even want to have to take off the rear wheel.)
I'm willing to spend up to a hundred bucks to have something reliable I can take out and put away and not worry about. So here's the pump I'm thinking about:
https://www.pumpagents.com/JabscoPumps/12290-0274.html
I'll admit that part of the appeal of a heavy pump like this is that it can sit at the bottom of my apparatus and turn it into something that's difficult for me to accidentally kick over. Part of what I might be screwing up is whether room-temperature Swepco will have a viscosity issue with this pump.
The idea of the M22 fitting that could screw into the fill cap threads is interesting. But it also seems like more work than a hook and it doesn't look like it allows easy air venting. Maybe there's already venting in the case somewhere?
But a stout pump, an easy-to-access switch and a hooked end for a clear tube seems like it will do the trick for me. All in a form factor I can pick up and put away in a cabinet and forget about for 12 months.
What am I missing, other than good sense?
Old 05-25-2018, 11:23 AM
Schleprock
KTL's Avatar
That pump is 700 bucks?
The M22 port fitting will work fine. The trans case has a vent port on the top "spine" of the trans. I figure if you gotta pull the fill plug out anyway, might as well screw in (by hand is all that's needed) a nice clean adapter fitting to fill it up. Only downside I see is that you can't monitor the amount you fill it. So you'd fill it up a little extra and then let the excess drain out the port when you remove the hose fitting?
Kevin L
Past: '87 Carrera
Old 05-25-2018, 11:31 AM
Administrator
Jack Olsen's Avatar
Only $50 on Ebay.
Old 05-25-2018, 11:32 AM
82 SC's Avatar
yea $700! Get the one i mentioned from northern hydraulics and get a coupon. $125 with coupon and be done with it. Put air to it and pull the trigger, easy..
1982 SC "Spooky"
Old 05-25-2018, 11:33 AM
964TargaC2's Avatar
I have been using a 12v "Oil change" pump, I think Harbor freight has them, mine is from JC Whitney (back in the day). Instead of pumping oil out of the engine through the dipstick housing (as it was intended for) you put the suction tube in the gear oil and the discharge hose into the transmission
what condition my condition is in
Old 05-25-2018, 11:35 AM
82 SC's Avatar
for video
1982 SC "Spooky"
Sboxin's Avatar
Trans fluid pump ideas
Another option for those who have a trans fluid cooler pump . . .
Unscrew the out connection and attach clear plastic hose to bucket/milk jug and turn on cooler pump . . .
Then reattach out connection and unscrew in connection and attach hose to Swepco
milk jug of new fluid and turn on cooler pump . . .
Reattach inlet connection from cooler and done . . .
Permanent mounted pump ready to use for anytime . . . doesn't everyone have a trans cooler . . . JK . . .
Regards,
Roy T
2002 Porsche Boxster S Cobalt Blue/Blk/Blk
Crew Chief for Son's 1978 Porsche 911SC Brown 3.8L NASA race car
Previous Porsches: 1958 356 Red Coupe - 1972 914 Blue -1972 911T Coupe Aubergine
Old 05-25-2018, 02:28 PM
HarryD's Avatar
consider a diaphragm pump like this: https://www.grainger.com/product/DELAVAN-AG-PUMPS-Polypropylene-Diaphragm-Diaphragm-55NL39
$37.80 and 12VDC so you can run it off your car battery.
Harry
1973.5 911T Targa - "Smokey"
2003 BMW Z4 3.0i
2009 MB C300
Old 05-25-2018, 04:45 PM
I use a 60 year old Sears paint pot to pump gear lube. Take your Sweepco one gallon jug & place in the paint container with the "fluid out" tube inserted in the gear lube jug. Fasten lid. Insert 20lbs. of air from a compressor. With 20lbs., the Sweepco flows pretty good, even at room temp. Best part is no clean up except for the tube submerged in the gear lube.
I'd post pictures but sadly I'm stuck with Windows 10.
Old 05-25-2018, 07:19 PM
Topocalma
+1
I did this with a big funnel at the top that I hung from the ceiling. Works even without heating it if you give it time and the equipment will def. be reusable next time. Best about it it is setup quickly and gravity works on its own while you can work on other things.
That being said one question: I filled it by gravity until it started to run out of the filler oil. This is finde according to Wayne's book. - no need to 'pressure fill' beyond that point??
1973 2,4T gemini blue
1977 3.0 Turbo slate grey
Old 05-25-2018, 11:39 PM
HarryD's Avatar
Originally Posted by Topocalm View Post
+1
Nope. Just fill until it overflows and close up.
Harry
2003 BMW Z4 3.0i
2009 MB C300
Old 05-26-2018, 03:32 PM
