82 SC's Avatar
Originally Posted by jlex View Post
Looks like you'll need a lift to use it...
I don't think you need a lift but i have one. The hose is long and flexible. When i get to use it I will post to see how it does on lift and not on a lift.
1982 SC "Spooky"
1961 VW Single cab truck
1966 VW Deluxe Hard top
Old 05-31-2018, 05:07 AM
sugarwood's Avatar
Had a nice metal suction gun that had to be refilled and was a leaky mess, so no thanks...
Metal suction guns are crap.
Refer to the one I posted.
100% airtight.
1986 3.2 911 coupe.
Old 05-31-2018, 05:22 AM
175K911's Avatar
Originally Posted by Sboxin View Post
Another option for those who have a trans fluid cooler pump . . .
Unscrew the out connection and attach clear plastic hose to bucket/milk jug and turn on cooler pump . . .
Then reattach out connection and unscrew in connection and attach hose to Swepco
milk jug of new fluid and turn on cooler pump . . .
Reattach inlet connection from cooler and done . . .
Permanent mounted pump ready to use for anytime . . . doesn't everyone have a trans cooler . . . JK . . .
Regards,
OK, now I feel really stupid. I have the Wevo trans cooler and spray bar, never even considered the fact that I have a built in pump for fluid changes. You just made my day!
Ed
'86 911 Coupe (endless 3.6 transplant finally done!)
'14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one)
'97 BMW 528i (the sensible car, bought new)
'12 Vintage/Millenium 23' v-nose enclosed trailer
Old 06-01-2018, 02:29 AM
shoooo32's Avatar
I just tried out this OEM Tools pump and it worked flawlessly.
Pour in three quarts of Swepco, connect the hose, pump a dozen times and stand back. Five minutes later the reservoir is empty and the transmission filled. Unscrew the included connector and the job is done.
At $135 it isn't cheap, but I've thrown away half a dozen $15 pumps and burned up untold amounts of paper towel cleaning up spills. I wish I had this a long time ago.
Instagram: @shoooo32
Old 06-04-2018, 09:34 AM
David in VA's Avatar
Try the Motive one. Similar and works great for under $90.
'87 911 Coupe
'95 911 Coupe
'04 911 GT3
'98 Jeep Wrangler
Old 06-05-2018, 08:49 AM
Administrator
Jack Olsen's Avatar
I'm bringing this thread back up because today I got around to putting my Swepco pump thing together.
My original plan was to put the pump and reservoir inside a 5-gallon bucket, for easy portability, but the bucket just wasn't the right shape. I sized up a plastic storage box, but then hit upon the idea of just making a handle to attach to the motor housing with the reservoir attached to the handle.
I'll need to make/find a cover for the reservoir so I don't get debris in it while the thing's stored inside a cabinet. But the basic idea is simple -- a reservoir with a screened drain, an impeller pump, and a line with a hook that can sit inside the fill hole for the transaxle.
I've tested it with water, and the $700 (but $50 on Ebay) pump produces enough pressure that I'd worry about it shooting back. But I suspect that will slow down with the more-viscous gear oil. Still, maybe I'll fit one of the barbed holders from one of my old pump setups to make sure it doesn't jet back out.
I've got some Swepco on order, and I'll report on the thing when it's been tested for real. The cost was under a hundred bucks, which is ridiculous when you compare it to the price of some tube and a funnel, I know -- but that was pretty much the point of my original post.
Old 09-11-2018, 11:59 AM
Looks like it should do the job...
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 09-11-2018, 12:39 PM
HarryD's Avatar
Just get a bug sprayer from Home Depot. $20
https://www.homedepot.com/p/Hudson-1-Gal-Plastic-Weed-N-Bug-Eliminator-Sprayer-13622600/206930639
Harry
1973.5 911T Targa - "Smokey"
2003 BMW Z4 3.0i
2009 MB C300
Old 09-11-2018, 05:39 PM
ADDvanced's Avatar
I had a slight grind in 2nd so I did the swepco change, and now it's way worse. Never changing the fluid again.
@ADDvanced
www.gruvdesign.com
Old 09-12-2018, 06:21 AM
KTL KTL is online now
Schleprock
KTL's Avatar
Send a message via Yahoo to KTL
LOL
Let's not get crazy? Changing gear oil is a good thing and should be done as part of regular maintenance. The fact that you have a crunchy 2nd gear indicates there's more to it than just gear oil
Kevin L
Present: '86 Carrera, '79 911SC widebody conversion rolling racecar shell
Past: '87 Carrera
Old 09-12-2018, 06:29 AM
ADDvanced's Avatar
Maybe I'll get real crazy and add some sawdust.
@ADDvanced
www.gruvdesign.com
Old 09-12-2018, 06:41 AM
Schleprock
KTL's Avatar
Make sure it's mahogany sawdust. It's the most prestigious and I have it in my apartment.
https://youtu.be/Hzx8KHjQD6c?t=20s
Kevin L
Past: '87 Carrera
Old 09-12-2018, 06:55 AM
sugarwood's Avatar
Unless you're changing gear oil several times a day, anything beyond a decent suction gun is total overkill.
Particularly if you have a lift. 10 min job every few years.
But, nothing about non-appliance car ownership is rational! Engineer on!
1986 3.2 911 coupe.
Old 09-12-2018, 09:20 AM
Administrator
Jack Olsen's Avatar
I changed the Swepco today, and shot video of the pump in use. When I was done, I realized two things: 1) It now only takes about 72 seconds to fill the box, and 2) Watching 72 seconds of a reservoir emptying is super boring.
So I talked over the boring footage, and here's the video:
https://youtu.be/vgNVl3ROkBE
Old 09-12-2018, 11:10 AM
what about a little clickidy clack fuel pump anyone try that?
gptom's Avatar
I bought this hand pump 30 years ago. I can refill with car on the ground. 30 pumps & let it sit for a while so the oil flows over the gears. a couple more pumps till it oozes out the fill hole.
don't forget, remove the fill hole 1st
68 Beetle 68 to 72 sold
72 911T Nov 71 to present P/U @ factory Nov 19. Car was gift to myself for surviving the army
67 VW split window 74 to 76 sold
81 VW caddy 81 to present
Old 09-13-2018, 09:11 AM
midnight911's Avatar
A small water (fluid) pump from Harbor Freight. I have my friend (professional mechanic) power it using 12V (battery).
pretty much similar to Gear oil change is always a pain in the neck
1984 911 Carrera Coupe - 32C #73 - M64/05
1998 E36 M3 4dr
1989 E30 325i 4dr
2006 Sienna 5dr - the hauler
2010 Cannondale Caffeine II - Lefty
Old 09-13-2018, 10:36 AM
