-   -   Injectors (http://forums.pelicanparts.com/porsche-911-technical-forum/997690-injectors.html)
Smokerider 05-26-2018 06:37 AM
Injectors
Hi, I’m about to replace several injectors o rings after discovering a vacum leak. I’m thinking about cleaning the injectors while they are out. How do you guys clean them or should I have them professionally cleaned? Thanks dave
shadowjack1 05-26-2018 06:40 AM
Send them all to Mr. Injector. He will clean them and test them and send you a report. Abouth $125.00
Lyle O 05-26-2018 07:45 AM
Yup, several services that clean and flow-test them. I used InjectorRX in Houston; they were a little cheaper ($108 plus shipping) and gave me a very nice report.
madcorgi 05-26-2018 09:15 AM
I used Dr. Injector. They did nice work. Had to replace one because of a non-repairable leak. It was a little tough finding a new one at a reasonable price (Dr. Injector did not cary the right one).
Smokerider 05-26-2018 10:23 AM
Thanks guys for the advise, I'm going to remove them and send them out for evaluation / cleaning dave
SCadaddle 05-26-2018 11:10 AM
What kind of injectors do you have? I don't think that Mr. Injector will clean/refurbish the CIS type injectors, or at least they didn't last time I looked.
Walter_Middie 05-26-2018 12:04 PM
I sent mine to Witch Hunter
https://witchhunter.com
Smokerider 05-26-2018 01:35 PM
Yes I haveCIS injectors....
bigel 05-26-2018 02:02 PM
Dave,
I sent my injectors to Mr. Injector (Bill Johnson) in Dalton Gardens Idaho. They give directions on how to pack, wrap and seal the injectors in zip-top bags for shipping to them.
Bill did a great job on my injecotrs - ultrasonic cleaned, tested for flowrate and spray pattern, oiled and painted for $17.50/ea. Report provided upon return showing performance before and after service for each injector.
Quick turnaround as well. I was very happy.
Can’t recommend Mr. Injector enough.
Smokerider 05-26-2018 05:50 PM
That's what I needed to hear- I'm going to send them to Mr Injector. Thanks for the recommendation!
Smokerider 05-26-2018 06:32 PM
KOH 05-27-2018 04:17 AM
+1 Mr. Injector - outstanding service
bigel 05-27-2018 06:18 AM
Happy to help. I find this forum priceless in so many ways, getting solid recommendations prior to pulling the trigger on a purchase/service is just one of them. One other item I forgot to mention, which should be obvious, is Bill also replaces all of the ‘wear parts’ O-rings, etc. as part of the service.
Be sure to post your experience once you get them back.
By the way, I was able to dig out some pics of my injectors, before and after servicing.
http://forums.pelicanparts.com/uploa...1527426779.jpg
http://forums.pelicanparts.com/uploa...1527426551.jpg
Good luck!
mepstein 05-27-2018 11:54 AM
Ive sent about 200 injectors to Mr Injector. Happy every time. He replaces all the needed seals and screens and flow tests before and after. Makes them look like new.
Smokerider 05-29-2018 06:31 AM
Injectors
Just got off the phone with Mr Injector, he does do CIS injectors As noted. He did say he does not do the CIS that injects directly into the cylinders
, but if the injectors mount into the intake manifold he does them. Hope this clears up any misunderstanding. Dave
