Another shim question...
My fan belt is too loose and makes that horrible screech when I give it a throttle blip. Today Charlie and I pulled the nut off and it turns out all 6 shims were already on the outside. Is it safe to add another one or two? Or is 6 the max? I was hoping there were a few on the inside to move out, but no dice. How else do I tighten it a bit? Thanks.
2022 BMW 530i 2021 MB GLA250 2020 BMW R1250GS |
Richard:
You don't tighten the belt by adding spacers on the outside, in fact don't add any more spacers anywhere. You need a different fan belt, either slightly shorter or wider. Take the one on there to Auto advantage and go crazy in the fan belt section.
'94 CMC Firebird Trans Am '86 951 LS1 (C-2) Gone ![]() ![]() '77 911 3.2 (C-1) Gone but not forgotten. http://www.pelicanparts.com/MotorCity/marcesq1 http://www.youtube.com/user/958Fan#p/u |
Yup, when all 6 spacer are on the outside, your belt is likely stretched, worn or too big. FWIW, the spare belt that came with my car has the numbers: 999.192.176.50 and 9.5 x 710 FA 3G printed on it. It's a Porsche/Goodyear belt in a OE Porsche cardboard sleeve. I believe this is the right one; I'm sure someone here will have more definitive info. Also, be sure to buy a spare when you get your replacement.
Argo 88 Targa |
Richard,
I just replaced my fan belt on my '84 Carrera. I used a 10x710 MM belt that I got from Pelican. You only use 6 total shims. I ended up with 2 on the inside and 4 outside the pulley. Like the others have said, you probably have the wrong size belt or it's stretched. Bruce
Bruce '12 Carrera S DFI '84 911 Carrera |
Alright, I'll try a new belt. Though this one is new and comes from a reliable source. That's next weekend's project. Thanks.
you may have a 9.5 X 725 instead of the 9.5 X 710
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
So far I see 9.5x710 and 10x710. Which is it?
Irrationally exuberant
-Chris |
Richard, you didn’t say if you have any shims on the inside of the pulley? Don’t you need 2 before the pulley on your Carrera? I assume you don’t have any between the pulley halves. So the problem sounds like you can’t get the pulley tight enough because it is not “seated” on the alternator shaft w/o those 2 inside shims.
Richard - check your e-mail.
Also, 710 is the critical size b/c that is the length of the belt (in mm I believe) while the 9.5/10 is the width.
Doug '81 SC Coupe |
FWIW...try for a "true" 9.5..not 10, or even a 9.5/10.... that is only an inventory saving size for the manufacturer.
Check also that the oblong rectangle isn't "hogged out" on the pulley half. That might be the problem, too. Correct procedure is to use 6 shims total...with whatever number you need ( up to 6) under the pulley...BUT...DO put the unused shims on the outside of the pulley under the nut..otherwise you're prone to more problems once you tighten the nut. ---Wil Ferch
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
