-   -   CIS trouble - low idle during warm up (http://forums.pelicanparts.com/porsche-911-technical-forum/997853-cis-trouble-low-idle-during-warm-up.html)
deftom 05-28-2018 02:01 AM
Hi guys,
I have a friend who have some problems with his car.
On cold start, the car is doing some yoyo during the first 2 minutes. After that, the iddle gows down to 500 RPM and slowly reaching 950 RPM.
When the car is hot, it works preaty well.
Here is the car configuration :
- it's a 3.2 with a 3.0 SC european engine
- the fuel distributor came from a 188 HP engine
- the Wur came from a 204 HP engine
- the auxiliary air valve closes within 8 min
- the engine was recently rebuild with 964 cams and Malhe 97 mm pistons
- all the CIS parts were rebuild and setup correctly and or tested separately
- the mixture was setup to 2.7
- all the ignition parts are also new
We sticks with this problem for a while and couldn't figured out was causes the issue.
I hope I made myself clear enought :).
Thanks a lots for your help.
cheers
boyt911sc 05-28-2018 06:19 AM
CIS troubleshooting.........
Originally Posted by deftom (Post 10052515)
Hi guys,
cheers
I like to help you but your information is too vague. Please provide the following:
FD ID Bosch number
WUR ID number
AAR ID number
What do you mean mixture set @ 2.7?
What are your fuel pressures readings (cold, warm, and system)?
How is the integrity of the vacuum system? Did you test it?
Keep us posted. Thanks.
Tony
deftom 05-28-2018 11:23 PM
Hi Tony,
Thanks for your help.
here is the information you asked :
FD ID Bosch number : 0438 100 031
WUR ID number : 0438 140 089
AAR ID number : 0280 140 201
What do you mean mixture set @ 2.7? 2,7% measured with a gunson gastester
What are your fuel pressures readings (cold, warm, and system)? Cold = 1b @7° celsius, Warm = 3,1b without vaccum (3,8b with vaccum), System = 4,5b
How is the integrity of the vacuum system? Did you test it? Yes, everything seems to be fine
deftom 05-30-2018 06:18 AM
Hi guys,
After few research, I foudn something that my be our problem :
http://forums.pelicanparts.com/porsche-911-technical-forum/893455-1981-sc-cis-low-idle-wrong-wur-6.html
I'll keep you in touch if it's that.
Cheers :)
fred cook 05-30-2018 07:35 AM
You also need to check the AAR and make certain that it is opening and closing properly.
deftom 05-30-2018 07:38 AM
Actually, He already tested it. When it's cold, the TAA is open and i took 8 min to close.
pmax 05-30-2018 09:24 AM
Have the timeline for the FP as well ?
