1982 911SC Vacuum
Hello to all members. I am new to the forum and a first time Porsche owner.
I recently bought a 1982 911SC and the car idles high around 1400 rpm. Reading up on this forum I tried to find vacuum leaks. I removed the boot from the throttle body and used a glove to seal it. I tried to pressurize the system through the vacuum hose from the WUR. However, the system does not hold any pressure what so ever. It seems like there is a huge opening behind the engine/throttle body that is open. What am I missing here? Appreciate any inputs. |
Did you plug the exhaust?
Vacuum test........
Blue, Did you plug the two (2) vacuum hoses attached to the throttle body rubber boot? Pictures will be helpful. Keep us posted. Thanks. Tony |
I have attached pictures.
Still here
If I can see your pic correctly, that hose (green oval) basically goes to open air.
Given your car is running, did you try spraying around with your favorite volatile to check for leaks ?
What the lark ! |
The green oval is vacuum hose out the WUR. I connected it to my compressor reservoir.
Still here
What the lark ! |
The Mighty Pieholio
If you have a leak, wet your hand with water and reach around the back and your hand will get cool if air is escaping.
1981 911SC Targa |
The Mighty Pieholio
1981 911SC Targa Last edited by Bob Kontak; 05-28-2018 at 10:13 AM.. |
The picture is not clear. See attached and follow the green line.
The Mighty Pieholio
First thing I would do is put my JB Weld skills in play. A little dremel action too, on a piece of heavy plastic. Get the 24 hour JB Weld.
Then test again.
1981 911SC Targa |
Still here
Bad eye.
Darn optical illusion.
What the lark ! |
The Mighty Pieholio
Third slat over from left. Is it intact or is it open to air?
1981 911SC Targa |
Still here
Are these plugged ?
(Not mine) ![]()
What the lark ! |
The airbox looks intact. No cracks or bowing. It's a little dusty and that might have created another optical illusion.
The Mighty Pieholio
OK. What we were seeing would have jumped out at you with being there. Also, no way in hell your car would have ran even badly.
1981 911SC Targa |
Still here
Plug both.
The throttle body ports are normally not open but check them anyway. A hose could have fallen off.
What the lark ! |
I can see the engineers who designed the car laughing at me, trying to use a mirror to see what hoses are to be plugged and what have come off. Wish they design a service window behind the rear seat. Time to buy a selfie stick to stick my phone back there to see what’s going on.
Thread Tools | |
Rate This Thread | |
Tags |
911sc , vacuum leak |
