DerkPerk's Avatar
3.2 plug and wire suggestions
So I completed my annual oil change the other day and while checking my final fill level, I saw a couple rogue sparks coming off a plug wire!
With so many options offered from our host, I’m at a loss at which I should pick. Any help would be appreciated.
Old 05-18-2018, 12:32 PM
Pedro '84 Coupe's Avatar
Am very pleased with the set from Clewitt Engineering. Make sure you buy new clips/holders for 8mm wires. These are connected to NGK spark plugs.
2000 Boxster S and 2016 Audi A6
Old 05-18-2018, 12:38 PM
madcorgi
Guest
Posts: n/a
+ 1 on the Clewetts.
Old 05-18-2018, 05:00 PM
Fleabit peanut monkey
Bob Kontak's Avatar
That's a +1.
Folks like Magnecor as well.
I put an MSD box under my drivers seat and mounted the coil where the CDI box was on the wall. Clewett made an extra long coil wire to accommodate. Not earth shattering in what they did but they were "Oh, easy peasy". Nice touch.
1981 911SC Targa
Old 05-18-2018, 05:09 PM
SCOTITUDE's Avatar
Send a message via AIM to SCOTITUDE
Magnecor on the 3.0l
Clewett on the 3.6l
both good
1980 911SC #99 track car, 993 3.6, 50 PMO's
2019 Ford F150 da dragger
2015 MB SL400 wifey DD
2008 E93 M3 DD
2007 E60 530 wifey winter beater
Old 05-18-2018, 05:49 PM
DerkPerk's Avatar
Thanks for the info. I’m thinking that I should do disty cap and rotor along with plugs as I can’t find a record of those being done on the car. Any recommendations on those items?
Thanks all
Old 05-19-2018, 08:33 AM
3.4 Bigger is better
88-diamondblue's Avatar
I have had both on my 88. Both were great. I made the mistake of not putting the wire in the right place and was sucked into the fan.
Michael
88 911 Diamond Blue CE Carrera 3.4 HC3.4 member
2020 Honda Passport
Old 05-19-2018, 09:30 AM
DerkPerk's Avatar
So my Magnecor wires showed up the other day and found a little discrepancy during the install. The coil connection ends on the Beru wires that were installed and the new Magnecor set are very different. Would like some opinions on this. Beru on the left
Old 06-03-2018, 02:59 PM
