-   -   rear end lift (http://forums.pelicanparts.com/porsche-911-technical-forum/998534-rear-end-lift.html)
85911 06-03-2018 07:01 PM
rear end lift
I have an 85 911 Targa and would like to know if I can lift the rear end of the car with a block of wood on a floor jack from the bottom of the engine pictured below.
I would do this to simply move the rear end a few feet in the garage.
The motor and transmission mounts are new.
Thanks.http://forums.pelicanparts.com/uploa...1528081190.jpg
DRACO A5OG 06-03-2018 07:45 PM
Yes you can let me mark where.
http://forums.pelicanparts.com/uploa...1528084033.jpg
Here you go, just place jack here and use a several rags or thin phone book. Just center at the split and raise slowly and lower slowly.
Jesse16 06-04-2018 04:52 AM
Same comment, yes. I don't do this frequently but when you want the back up to address the bumper or just rear wheels and have the space behind for the long floor jack required this works well. A bit nerve wracking so go slowly.
Flojo 06-04-2018 05:14 AM
Originally Posted by Jesse16 (Post 10061245)
Same comment, yes. I don't do this frequently but ...
+1
then one day I baugt this jackmount... (eBay user: tangerine911)
http://www.imgbox.de/users/public/images/PvxLX173Z5.JPG
MARISOL78sc 06-04-2018 06:53 AM
Flo,
That is a tow hook. I would not use that as a jacking point.
Jesse16 06-04-2018 06:58 AM
I think you jack at the black round point which attaches directly to the engine mount and support bar. No jacking on the red towing part.
LIRS6 06-04-2018 07:05 AM
Originally Posted by Flojo (Post 10061270)
+1
It may be the angle of your photo, but is your sump pump plate properly positioned? looks like the plug might not be oriented correctly.
MARISOL78sc 06-04-2018 07:16 AM
Yes,
I believe you are correct!
85911 06-04-2018 10:12 AM
Thanks for the replies.
HarryD 06-05-2018 09:11 PM
Frankly, there are many decent jack points on a 911.
Why would you want to lift your car using the most expensive to repair component in your car?
Originally Posted by Bill Verburg (Post 2271577)
X's for lifting O's(and X's for stands), there are others, the Os are almost impossible to get a jack on
http://forums.pelicanparts.com/uploa...1133618043.jpg
safe 06-06-2018 12:41 AM
+1
I welded up my own version of this. Best cheep mod ever...
safe 06-06-2018 12:47 AM
There are very few for lifting the rear that is safe and stable and accessible.
Hot Euro 06-06-2018 04:27 AM
I resisted this method for quite some time but after buying a new jack and double checking Wayne's book I gave it a try. I am now a believer.
This pic is from Wayne's "How To"
http://forums.pelicanparts.com/uploa...1528287908.jpg
Flojo 06-06-2018 05:11 AM
I don't like this way.
for old engine versions with a fule pump sump plate, I'd highly recommend to use some wood or similar in strengh to absolutely avoid denting the plate!
or at least point the jack more aft to avoid the plate at all!
proporsche 06-06-2018 05:55 AM
I have been using the engine case lift of the the car since 1980`s .My teacher ex Zuffenhausen mechanic told me that is fine.If you have a rubber pad on your jack there is no harm whatsoever done to your engine case or strainer plate.Some people do not like it as i can see above , but most 911 mechanic use this method all the time...
ivan
Flojo as said above your strainer plate is installed wrongly the drain plug has to be on left side....
JAR0023 06-06-2018 06:30 PM
Hockey puck on the jack saddle makes a good pad for lifting by the engine case. Actually makes a good saddle pad, period.
Mark Salvetti 06-07-2018 03:34 AM
If he still has the old style sump screen then the drain plug can be oriented like he has it. You only need to orient it to the left when you upgrade to the new style screen. I know because I made this mod to my car about 20 years ago.
Mark
proporsche 06-07-2018 05:00 AM
Hi Mark....that is version
Ivan
Flojo 06-07-2018 05:20 AM
all is well SmileWavy
http://up.picr.de/30376068xu.jpg
proporsche 06-07-2018 06:17 AM
looks mighty clean under..just missing a muffler;-)
Ivan
Copyright 2018 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
