85911's Avatar
rear end lift
I have an 85 911 Targa and would like to know if I can lift the rear end of the car with a block of wood on a floor jack from the bottom of the engine pictured below.
I would do this to simply move the rear end a few feet in the garage.
The motor and transmission mounts are new.
Thanks.
1985 911 Carrera Targa, 1951 Harley Davidson Panhead Chopper, 1957 Harley Davidson Panhead- stock, 1972 Yamaha 250 DT-1, 1959 Austin Healey (Bug Eye) Sprite- sold, 1959 Austin Healey (Bug Eye) Sprite- sold, 1960 Austin Healey (Bug Eye) Sprite- sold
Old 06-03-2018, 07:01 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Yes you can let me mark where.
Here you go, just place jack here and use a several rags or thin phone book. Just center at the split and raise slowly and lower slowly.
'85 Carrera Targa
PCA/POC
Old 06-03-2018, 07:45 PM
Spiderman
Jesse16's Avatar
Same comment, yes. I don't do this frequently but when you want the back up to address the bumper or just rear wheels and have the space behind for the long floor jack required this works well. A bit nerve wracking so go slowly.
Midnight Blue 08 Cayman S, Fun/Track
Black 12 VW-GTI, work
Mexico Blue 87 Carrera, sold, sad, not enough garage space.
Old 06-04-2018, 04:52 AM
Flojo's Avatar
Originally Posted by Jesse16 View Post
Same comment, yes. I don't do this frequently but ...
+1
then one day I baugt this jackmount... (eBay user: tangerine911)
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
https://www.instagram.com/spadescustomz_/
https://www.instagram.com/911garage_germany/
https://www.facebook.com/911garage
Old 06-04-2018, 05:14 AM
MARISOL78sc's Avatar
Flo,
That is a tow hook. I would not use that as a jacking point.
Paul
2011 Cayman S | 1978 911 SC | 2007 Lexus IS 350
1995 993-Sold |1998 C2S-Sold | 2002 M3-Sold
Old 06-04-2018, 06:53 AM
Spiderman
Jesse16's Avatar
I think you jack at the black round point which attaches directly to the engine mount and support bar. No jacking on the red towing part.
Old 06-04-2018, 06:58 AM
Originally Posted by Flojo View Post
+1
It may be the angle of your photo, but is your sump pump plate properly positioned? looks like the plug might not be oriented correctly.
'79 911SC Targa
Old 06-04-2018, 07:05 AM
Yes,
I believe you are correct!
Paul
Old 06-04-2018, 07:16 AM
85911's Avatar
Thanks for the replies.
Old 06-04-2018, 10:12 AM
HarryD's Avatar
Frankly, there are many decent jack points on a 911.
Why would you want to lift your car using the most expensive to repair component in your car?
Originally Posted by Bill Verburg View Post
X's for lifting O's(and X's for stands), there are others, the Os are almost impossible to get a jack on
Harry
1973.5 911T Targa - "Smokey"
2003 BMW Z4 3.0i
2009 MB C300
Old 06-05-2018, 09:11 PM
safe's Avatar
+1
I welded up my own version of this. Best cheep mod ever...
Magnus
911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. Just works!
911T Coupe -69, 3.6, G50, "RSR", track day. Sorting out issues...
924 -79 rat roddy...
931 -79 under total restoration...
Old 06-06-2018, 12:41 AM
safe's Avatar
There are very few for lifting the rear that is safe and stable and accessible.
Magnus
Old 06-06-2018, 12:47 AM
Old car guy.....
Hot Euro's Avatar
I resisted this method for quite some time but after buying a new jack and double checking Wayne's book I gave it a try. I am now a believer.
This pic is from Wayne's "How To"
1981 SC Steel Widebody, DP Lid, 930/51 to 3.2l, K27 7006 Turbo, DOD, P&P Twin Plug heads, Twinfire Ignition, Ruf Intercooler, Powerhaus headers, Zork, CIS Euro FD, 009 injectors, 044 pump, BLwur, 930 4 sp LSD, Mocal 44 w/fan, LM2, Brembo, Retroair, Euromeisters
2003 BMW Z4 Daily Driver & Autocross car.
Old 06-06-2018, 04:27 AM
Flojo's Avatar
I don't like this way.
for old engine versions with a fule pump sump plate, I'd highly recommend to use some wood or similar in strengh to absolutely avoid denting the plate!
or at least point the jack more aft to avoid the plate at all!
Old 06-06-2018, 05:11 AM
proporsche's Avatar
I have been using the engine case lift of the the car since 1980`s .My teacher ex Zuffenhausen mechanic told me that is fine.If you have a rubber pad on your jack there is no harm whatsoever done to your engine case or strainer plate.Some people do not like it as i can see above , but most 911 mechanic use this method all the time...
ivan
Flojo as said above your strainer plate is installed wrongly the drain plug has to be on left side....
1985 911 with original 491 615 miles..791 177km.
"The difference between genius and stupidity is that, genius has its limits". Albert Einstein....
Old 06-06-2018, 05:55 AM
Go-Kart Mozart
JAR0023's Avatar
Hockey puck on the jack saddle makes a good pad for lifting by the engine case. Actually makes a good saddle pad, period.
Old 06-06-2018, 06:30 PM
Mark Salvetti's Avatar
If he still has the old style sump screen then the drain plug can be oriented like he has it. You only need to orient it to the left when you upgrade to the new style screen. I know because I made this mod to my car about 20 years ago.
Mark
1979 911SC Targa
Old 06-07-2018, 03:34 AM
proporsche's Avatar
Hi Mark....that is version
Ivan
Old 06-07-2018, 05:00 AM
Flojo's Avatar
all is well
Old 06-07-2018, 05:20 AM
proporsche's Avatar
looks mighty clean under..just missing a muffler;-)
Ivan
Old 06-07-2018, 06:17 AM
