Getting fiberglass fenders to a presentable finish
Good morning - looking at a car with front flared fenders in fiberglass. I know the answer is "it depends", but for driver quality paint these shouldn't be prohibitive to get sorted out, will they?
Panel fit, and related bumper fit etc, is the bigger issues than paint, right? Anyone been there, done that, and survive it?
1967 912 (now w/ 50% fewer random holes in it) 911 w/ 3.2 1974 914 (3.2L swap underway) 1984 928s (S4 engine and suspension), 1987 928S4 |
I put fiberglass bumpers, fenders, frunk, and decklid on my race car. It was hard to tell they weren't steel. The paintwork was indistinguishable from the steel parts, you had to look under to see.
You'd need to fill/grind the edges to make the panel gaps look right; there's a well established technique for it you can lookup. Then skimcoat and sand a couple times to get surfaces smooth and straight.
Steve '66 912 - Polo Red; '74 911s - Silver Carrera RS clone '77 911s - Peru red IROC Clone '89 964 C4 - Guards red |
Thanks Steve
Mine bolted right up, almost perfect surface out of the box too
(MA Shaw) My front bumper needed a lot of work (GT racing)
73 RSR replica (soon for sale) SOLD - 928 5 speed with phone dials and Pasha seats SOLD - 914 wide body hot rod My 73RSR build http://forums.pelicanparts.com/porsche-911-technical-forum/893954-saving-73-crusher-again.html |
Thanks Wayner, man she looks good/mean.
I would rather be driving
That is a bumper problem. Looks like it was not mounted/fit correctly. Also looks like NB bumper on flared fenders.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
Thanks Skip!
I tried to find pictures of my front bumper under construction.
If I find them Ill post them but, essentially took cuts out of the bumper in some places, and used metal foil tape as backing to build new fiberglass on to fill the few inch gaps that were needed. Next, once it was all one piece again, took curf cuts out of it in order to expand the profile of the end of the bumper to meet the flare exactly properly. Again, created new fiberglass in between (also, note that the factory SC-CR car had a bumper that did not match the flare - it was a limited run of race cars using off the shelf parts form different models, and fit dint matter much on race cars back then, I doubt that is what we are looking at in your pic though )Unlike the bumper, here are pics of the MA shaw fenders fresh out of the box with no rework (bumper needed a bit of love) You might be able to find a pic on my build thread Saving a 73 from the crusher... ![]()
73 RSR replica (soon for sale) SOLD - 928 5 speed with phone dials and Pasha seats SOLD - 914 wide body hot rod My 73RSR build http://forums.pelicanparts.com/porsche-911-technical-forum/893954-saving-73-crusher-again.html Last edited by wayner; 06-04-2018 at 05:06 PM.. |
Fiberglass is easy to work with, but very labour intensive. You can get a nice finish and good quality paint, if you prepare the fiberglass properly. It will take much more work than with steel. But it can be done.
My car has fiberglass fenders, hood, bumpers and doors. To get it from at very rough urban driver, to a nice painted finish took a lot of work. ![]()
The fit is one thing, but in regard to paint...
Use a high build primer then sand it to fill in the minor pits and imperfections. There is some stuff you can either put on with a sponge or spray on, that you sand until the black stuff is gone. It shows as black in the pits and imperfections. And keep using this until it's perfectly smooth. Then you clean it off with prepsol or similar degreaser. Then you paint it. there is no reason why the paint finish won't be as good as if it was on steel. |
So not a fiberglass thing as much as a care/fit issue (so long as the fiberglass bits are quality). Fair summary?
Great color!
