Brake MC switch torque specs?
Hi, does anyone know the torque spec for the two pressure switches mounted on the master cylinder of a 3.2 Carrera? I've done a couple of searches with no luck. Thanks for the info!
Old 06-06-2018, 02:01 PM
The Bentley's manuel states.
15Nm (11ft-lb)
Old 06-06-2018, 02:30 PM
proporsche's Avatar
hi..any time you use you hand it is between 15-18 nm so hand tight is ok..
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 06-06-2018, 02:42 PM
Thanks for the information Dan and Ivan, appreciate it!
Old 06-06-2018, 03:27 PM
