86 911 Carrara fan and fan surround stuck.
So, after taking my car out of New England winter storage, I heard this funny noise coming from the fan area. An occasional low rumble. 86,000 mi original everything. So thinking it was coming from the generator bearings, I took the belt off and there was a tiny bit of play in the generator shaft if I wiggled the fan. But worse than that, one blade was hitting the housing, YIKES. Just a touch, but a hit. So I took the bugger off the car.
Now I can not 1:get the fan off of the generator, 2: can not get the generator off the fan housing. Please help. I have tried gentile tapping with a small hammer and a drift at the generator small mounting bolts, and at the back of the fan. No movement at all. I have noticed a few cracks in the housing! Yikes again. I see an aluminum one is available. The prices for the fan and the housing, both magnesium are high.
Does anyone make something that costs less?
All help greatly appreciated.
Old 06-06-2018, 01:45 PM
proporsche's Avatar
Hi ..search is you ansfer here on pelicans or google.
1.used wood and hold the fan housing in your hands ,let it drop onto the wood -use gravity.turn it in your hand a apply the same dropping procedure.
2.If you cannot get the fan of the alternator(not generator) i suggest ..again piece of wood and hold the fan in your hands let it drop onto the wood.use gravity ...and finally wd40 prior the gravity works......
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 06-06-2018, 01:55 PM
Sounds like the Carrera fan housing is broken in the area of the alternator base.
Use an eight mm Allen socket in the middle of the fan and hold fan with one hand tapping with a hammer on the Allen. Spin the fan as you tap.
Bruce
Old 06-06-2018, 03:46 PM
Wow, the wood gravity method worked so well it is silly. I took both pieces of in less than a minute.
Thank you so much.
Old 06-06-2018, 04:32 PM
Fleabit peanut monkey
Bob Kontak's Avatar
Thank you so much.
Awesome. Don't forget the 90+ minutes to actually get the fan in place for the wood trick.
90 mins if you are good.
1981 911SC Targa
Old 06-06-2018, 06:31 PM
proporsche's Avatar
one ex-Bostonian to another..i use to live in Roxbury;-) not so pretty place, thou;-)
u r welcome...
Ivan
Old 06-07-2018, 12:27 AM
madcorgi
Guest
Posts: n/a
Thank you so much.
It kind of seems like it defies physics, doesn't it? But it works.
Old 06-07-2018, 12:29 AM
